| OllieG |
Mar 28 2012, 02:30 PM
OllieG ![]() ![]() Group: Members Posts: 212 Joined: 6-July 11 From: UK Member No.: 13,282 Region Association: England |
Hi all, I haven't posted much on 914World so 'greetings from the UK'!
I'm converting a '74 to a 6cyl. Right now I'm replacing the rear trunk floor with an RD floor replacement and was hoping some of you guys could give some advice on how best to install it.. The previous owner did a heinous job in trying to repair the original floor with a flat sheet. I've cut and ground that out now. I still have some of the original floor edges to remove but am nearly ready to install the replacement floor. I'm wondering what's the best way to deal with the area across and over the transmission mounts?..this will be where the original floor will be cut and the new floor will be welded in. There is an additional reinforcing piece right above the transmission mounts which I feel will need to be removed as there are clear signs of rust beneath it, which needs sorting - see pic. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1235.photobucket.com-13282-1332966650.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1235.photobucket.com-13282-1332966650.2.jpg) Obviously once this piece is removed the strength of the 'beam' will be compromised. The RD panel has section pressed into it at this point to add stiffness(see pic)..but is it enough alone? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1235.photobucket.com-13282-1332966650.3.jpg) Has anyone else done this job?..and should I be worried about the strength of the floor above the transmission mounts with just the single layer of the RD floor? Hope this makes sense!! Thanks for any tips... Ollie. |
| 914werke |
Mar 29 2012, 02:22 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,742 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Isnt that plate available from RD also?
| OllieG |
Mar 29 2012, 03:02 PM
OllieG Trunk Floor Repair Mar 28 2012, 02:30 PM
SirAndy I've done that repair but on mine the double p... Mar 28 2012, 02:39 PM
OllieG Thanks Andy...will do that. I drilled out the rein... Mar 29 2012, 02:04 PM
gothspeed Good information on this thread :) Mar 29 2012, 02:23 PM
jmill
Any tips on bending radii into sheet accurately w... Mar 29 2012, 06:22 PM
jmill To form the joggle clamp the piece like so and ham... Mar 29 2012, 06:26 PM
OllieG
To form the joggle clamp the piece like so and ha... Mar 30 2012, 04:04 AM
9146986 What I do is take a Sharpie and ruler and make a s... Mar 30 2012, 06:51 AM
OllieG I've cut out all of the original floor now (ho... Mar 30 2012, 02:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th September 2026 - 03:39 AM |
