I'm converting a '74 to a 6cyl. Right now I'm replacing the rear trunk floor with an RD floor replacement and was hoping some of you guys could give some advice on how best to install it..
The previous owner did a heinous job in trying to repair the original floor with a flat sheet. I've cut and ground that out now. I still have some of the original floor edges to remove but am nearly ready to install the replacement floor.
I'm wondering what's the best way to deal with the area across and over the transmission mounts?..this will be where the original floor will be cut and the new floor will be welded in.
There is an additional reinforcing piece right above the transmission mounts which I feel will need to be removed as there are clear signs of rust beneath it, which needs sorting - see pic.
Obviously once this piece is removed the strength of the 'beam' will be compromised. The RD panel has section pressed into it at this point to add stiffness(see pic)..but is it enough alone?
Has anyone else done this job?..and should I be worried about the strength of the floor above the transmission mounts with just the single layer of the RD floor? Hope this makes sense!!
Thanks for any tips...
Ollie.
