| Prospectfarms |
Mar 27 2012, 06:32 AM
Member ![]() ![]() Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest |
Key off. Red terminal to body gives somewhere between 1V and 750mV. (IMG:style_emoticons/default/sad.gif) To me that seems like a bare wire short to ground but I'm not an expert.
Likely spots? Anyplace I could test first before tracing the whole electrical system? How about a short (N.P.I.) list of always-hot wires in the car. Doesn't have to be comprehensive -- just looking for a starting point. Thanks. |
| Prospectfarms |
Mar 29 2012, 10:36 PM
Sorry for the delay responding. Unfortunately I do not have a clock or radio.
There are only two defective circuits on this car I know of. The left-front parking lights and the right rear turn signals. The harness power lead on both is dead and the lights are powered by single wires spliced to their proper source under the dash. The old are taped off. 30 years ago the PO rigged a two-pole generic flasher relay to power the turn and emergency flashers. It remains in place. |
Prospectfarms 750mV from battery to ground Mar 27 2012, 06:32 AM
stugray What?
Does the car run?
You should have ~12-13 Vo... Mar 27 2012, 08:25 AM
Prospectfarms
What?
Does the car run?
You should have ~12-13 V... Mar 27 2012, 08:49 PM
ape914
What?
Does the car run?
You should have ~12-13 ... Mar 27 2012, 09:28 PM
Valy
What?
Does the car run?
You should have ~12-13 ... Mar 27 2012, 09:36 PM
Prospectfarms
[quote name='Prospectfarms' post='1655151' date='... Mar 27 2012, 09:51 PM
Valy 1St, your battery is dead.
Disconnect it and measu... Mar 27 2012, 10:36 AM
Prospectfarms
Disconnect it and meas... Mar 27 2012, 08:53 PM
underthetire To check ghost drains
Remove red wire from batter... Mar 27 2012, 11:36 AM
Prospectfarms
Remove red wire from batte... Mar 27 2012, 08:57 PM
Spoke Here's some basic voltages to check.
1) Measu... Mar 27 2012, 01:01 PM
Prospectfarms
1) Meas... Mar 27 2012, 08:59 PM
Prospectfarms If I understand what your saying, if there was onl... Mar 27 2012, 09:40 PM
kg6dxn The voltage you are reading could be capacitance f... Mar 27 2012, 10:00 PM
Prospectfarms
The voltage you are reading could be capacitance ... Mar 27 2012, 10:32 PM
rhodyguy try taking the inline fuse for the stereo out and ... Mar 28 2012, 11:18 AM
kg6dxn You want to measure amperage. You want to see less... Mar 28 2012, 05:18 PM
Prospectfarms Dugout my real mulitmeter. Replaced fuse and batte... Mar 28 2012, 07:26 PM
Valy You are good although 25mA for the stereo is a bit... Mar 28 2012, 08:32 PM
Prospectfarms
You are good although 25mA for the stereo is a bi... Mar 29 2012, 05:48 AM
Valy What else is always on? Clock? Mar 29 2012, 08:43 AM
warrenoliver
when I had batt... Mar 29 2012, 11:20 AM
kg6dxn Your drain seems a little high with no radio or cl... Mar 29 2012, 10:47 PM
Prospectfarms
Your drain seems a little high with no radio or c... Mar 30 2012, 09:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th November 2026 - 03:43 AM |
