Wednesday, 13 August 2025 |
edwin |
Member ![]() ![]() Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand ![]() |
Have had the car back on the road about a week now and have put nearly 1000km's on it (you do the math)
Have used nearly a litre of oil and i am sure that nearly none of it has been burned as there are signs of it all over the floor of the shed and the engine bay. one of the plugs I had on the right hand head vent came off and oil has sprayed everywhere in that area. I also put a breather filter on the oil fill box and there is lots of oil in the filter and on the box itself. Not sure if this should be worrying or normal. I plan to make a breather box when i get some time soon and am still debating plumbing the breather into the intake. Look forward to ideas and opinions Edwin |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Have had the car back on the road about a week now and have put nearly 1000km's on it (you do the math) Have used nearly a litre of oil and i am sure that nearly none of it has been burned as there are signs of it all over the floor of the shed and the engine bay. one of the plugs I had on the right hand head vent came off and oil has sprayed everywhere in that area. I also put a breather filter on the oil fill box and there is lots of oil in the filter and on the box itself. Not sure if this should be worrying or normal. I plan to make a breather box when i get some time soon and am still debating plumbing the breather into the intake. Look forward to ideas and opinions Edwin What engine? What induction system? What is the oil level in the engine (did you overfill it?)? If the engine is old and you have excessive blow-by, you're gonna puke oil out of the breathers. If FI and not a 1.8 L-Jet, do you have the PCV valve in the oil filler base? Head vents are piped to an anti-flashback valve and then to the air cleaner on a D-Jet. If you tie them all to a breather, it needs to be high above the engine so that oil will drain back to the crankcase. |
Lo-Fi Version | Time is now: 13th August 2025 - 07:58 AM |
