| tornik550 |
Apr 1 2012, 06:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
Long story how this happened however I was going to "upgrade" my front calipers to BMW 320i calipers. I was having the caliper flange machined and (long story) the flange is now a little too thin. The specs call for the flange to be 0.587" +/-0.005" and mine measure 0.539". Other than the obvious- scrap them and start with a new set- do I have any options? Can I can get a perfectly measured, very thin spacer and put it between the strut and the flange?
Also, are 19mm master cylinders needed for 320i calipers? |
rick 918-S 19mm master is needed or your peddle travel will b... Apr 1 2012, 08:16 PM
tornik550
19mm master is needed or your peddle travel will ... Apr 1 2012, 08:30 PM
edwin I put some of the Alfa 75 Brembo calipers on my ca... Apr 1 2012, 08:50 PM
rick 918-S Use the stock 914 calipers. Rebuild them with new ... Apr 1 2012, 10:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 10:25 PM |
