carb guru needed |
carb guru needed |
ruddyboys |
May 21 2004, 04:03 PM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
I have dual webber 40 IDF, the carb was leaking through the accelerator pump diaphragm. After replacing it the carb over flows throug the top? I checked the needle valve and it moves freely and is attached to the floats. The floats also move freely. Could it be the floats need to be adjusted, if so how. (IMG:style_emoticons/default/pissoff.gif)
tat2dphreak |
May 21 2004, 04:33 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
QUOTE(Rouser @ May 21 2004, 04:25 PM) Adjust your float levels per diagram. You tweek the two tabs accordingly until you get the desired clearances, and this is WITH the gasket installed. (IMG:style_emoticons/default/agree.gif) I had the SAME thing after I rebuilt my webers, pulled the top off, adjusted the float actuator(aka metal tab) and it worked like a champ... the weber book says something like when the needle is engaged, the float should be paralell with the carb |
Lo-Fi Version | Time is now: 29th May 2024 - 05:14 AM |
