Oil pipe question, 2.7s into 914-6 |
martin_UK914 |
Apr 5 2012, 08:28 AM
Newbie Group: Members Posts: 22 Joined: 9-April 11 From: UK Member No.: 12,913 Region Association: None |
Evening all...
Asking on behalf of my brothers car... not mine alas... Ok, so it was a '70 2.0L, and he did al the right stuff converting to a 6, like engine mounts, oil tank etc etc... all done properly. Now, we have dropped in a 2.7s einspritzen motor... (IMG:style_emoticons/default/w00t.gif) and obviously the oil pipes don't match up... the thread on the motor is different from the car. Is there an easy fix for this or does someone make a pipe to suit? Any help would be appreciated. (IMG:style_emoticons/default/biggrin.gif) |
sixnotfour |
Apr 6 2012, 02:10 AM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
The steel fitting on the engine, you need to change it, early are 26mm threads and the later are 30mm.
You need the early steel fitting that screws into the case. To use the 914-6 oil pipe. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:41 PM |
