Brake light switch, Help!!!!!!! |
boston914 |
May 22 2004, 10:03 AM
Member Group: Members Posts: 52 Joined: 15-July 03 From: Boston, MA Member No.: 912 |
I am trying to repair non-working brake lights.
This morning, I opened the pedal board, and inspected the switch. It looksto be in good shape. I cleaned some sticky stuff off the "washer" that contacts the switch, and now the brake lights work about 1 out of 3 times that I push the pedal. Can the switch or anything around it be adjusted? It looks like the "washer" moves away from the switch arm when the brake pedal is depressed, and this is supposed to activate the lights. Is it possible to lubricate the switch? I am wondering if the switch is somehow sticking, and not activating properly. (not releasing when the "washer" moves away??) I am really stumped, and my next step was going to be to just buy a new repalcement switch. Any help would be appreciated. Thanks. ------------------------------------------------------------------------ '76 Malaga Red |
Rusty |
May 22 2004, 10:39 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
A loose connection, or maybe a gummed up switch.
At this point, some spray electrical cleaner couldn't hurt. Spray the switch liberally, work the switch to try and get it good and clean. Make sure it's dry before you hook it back up. The switches are available, are about 50 bucks. Someone might have a used one in their stash, you could post a wanted ad. hope this helps, -Rusty (IMG:style_emoticons/default/smoke.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 03:52 AM |
