What Next?, Still runs like Shit! |
Levi |
May 22 2004, 07:21 PM
Lick my nuts Group: Benefactors Posts: 623 Joined: 11-March 04 Member No.: 1,783 |
Well I'm still stumped, Went through all the vacuum lines, Checked the plugs, cap rotor, points, wires.
When I started it up after putting everything back on, it still runs very bad, it cuts out all through the RPM range and the exhaust smells very rich, I unpluged the cold start valve but that made no difference. The plugs were all sooted up so I'm pretty sure its getting to much fuel. What do you think I should check next? |
Rockaria |
May 22 2004, 08:16 PM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
Like I said before, You might want to make sure the fuel lines bypass the cold start valve. The cold start valve can leak on its own (No electricity needed). Bypass it and see what happens. It only takes a few minutes. But make sure you have a high pressure Coupler.
Lo-Fi Version | Time is now: 2nd June 2024 - 05:05 PM |
