How low can you go?, Bump steer |
Lennies914 |
Apr 9 2012, 06:42 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
I am about to swap out my front control arms and I want to lower the front end some when I reassemble. I have a new bump steer kit to install. So I guess my question is; will the bump steer kit have any negative effect on the steering if I choose not to go too low?
r_towle |
Apr 9 2012, 07:23 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If you use the bump steer kit it raises the steering rack to change the geometry.
If you lower the a-arms beyond parallel with the ground, they will hit the lowest welded flange on the body when you compress the suspension...so there really is a physical limit. the bump steer kit is ok, but if you are running sticky rubber...it wont make a difference...your gonna get bump steer. rich |
Lo-Fi Version | Time is now: 10th June 2024 - 04:32 PM |
