Driveline Slop? |
Driveline Slop? |
andrewvolsen |
Apr 10 2012, 11:33 PM
Newbie Group: Members Posts: 44 Joined: 6-December 09 From: Santa Barbara Member No.: 11,099 Region Association: Central California |
I have a '75 1.8 and lately it has felt like there is more slop in the driveline than there used to be. If I let off the gas in 1st or 2nd I can feel the whole car sort of lunge/jerk, same thing happens if I get on the gas. It gets much less noticeable in higher gears. Is this a common issue? What should I check first?
My first suspicion was failing cv joints. I reached under the car earlier and tried rocking the passenger side axle back and forth, but I didn't feel any play. Andrew |
TheCabinetmaker |
Apr 11 2012, 09:05 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
An engine mount will usually transmit movement to the shifter. Use a pry bar between the case and mount bar and try to lift the engine off the bar.
Lo-Fi Version | Time is now: 11th June 2024 - 09:02 AM |
