WTB 1.8L Oil Breather Hose |
timothy_nd28 |
Apr 11 2012, 04:35 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Valy |
Apr 11 2012, 05:36 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
The hose is NLA. If you find a source, buy 2 and I'll take the other one from you on the spot.
Here is what I did and works perfectly: 1. Get 2 90deg 3/4" plastic elbows from Home Depot, Lowes, you name it 2. Get 3/4" rubber hose 3. Cut one side of one elbows as short as reasonably possible. This is the side that will be closest to the big rubber boot. 4. The fit is tight. Try to cut the hose inner lip to 45deg and use soap to fit them on the 22mm mounting lips. Result: (IMG:http://www.914world.com/bbs2/uploads/post-11573-1332384265_thumb.jpg) |
timothy_nd28 |
Apr 11 2012, 05:43 PM
The hose is NLA. If you find a source, buy 2 and I'll take the other one from you on the spot. Here is what I did and works perfectly: 1. Get 2 90deg 3/4" plastic elbows from Home Depot, Lowes, you name it 2. Get 3/4" rubber hose 3. Cut one side of one elbows as short as reasonably possible. This is the side that will be closest to the big rubber boot. 4. The fit is tight. Try to cut the hose inner lip to 45deg and use soap to fit them on the 22mm mounting lips. Result: (IMG:http://www.914world.com/bbs2/uploads/post-11573-1332384265_thumb.jpg) Very clever! |
Lo-Fi Version | Time is now: 1st June 2024 - 12:33 PM |
