| rwilner |
Apr 12 2012, 12:44 PM
No Ghosts in the Machine ![]() ![]() ![]() Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
I did a search and found a few threads, but I'm having kind of a hard time getting all the tar off the underside of the relay board to a clean surface.
I was able to chip a lot out. Then I tried a heat gun which really just turned it into goo -- didn't make it easier to remove. Then i soaked it in mineral spirits, which kind of gummed it up...I was hoping it would dissolve it. How can I get the underside pristine? Other chemicals (isopropyl alcohol)? Some kind of media blast? |
| JeffBowlsby |
Apr 12 2012, 01:57 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,385 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
It werks. (IMG:style_emoticons/default/smile.gif)
rwilner how to remove tar from relay board? Apr 12 2012, 12:44 PM
r_towle dry ice, gloves, chisel Apr 12 2012, 12:59 PM
rwilner
chisel
I'm hoping there's a chemical al... Apr 12 2012, 01:13 PM
Jeff Bowlsby Submerge the whole board in Acetone for a week, th... Apr 12 2012, 01:25 PM
rwilner
Submerge the whole board in Acetone for a week, t... Apr 12 2012, 01:33 PM
dlee6204 I stick my boards in the freezer overnight before ... Apr 12 2012, 02:07 PM
Midman914 Try Xylene, we use it at work to clean our tar bas... Apr 12 2012, 04:44 PM
ClayPerrine I just did this the other day.
Heat gun to soft... Apr 13 2012, 11:38 AM
Valy
I did a search and found a few threads, but I... Apr 13 2012, 12:14 PM
rwilner
Rich, if you can melt the tar with the heat gun,... Apr 13 2012, 12:16 PM
Valy
Rich, if you can melt the tar with the heat gun... Apr 13 2012, 12:54 PM
underthetire Goof off seemed to take it off. I heated mine up a... Apr 13 2012, 12:35 PM
02loftsmoor Berrymans B12 really loosened the tar up, still a ... Apr 13 2012, 01:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th November 2026 - 12:22 AM |
