> how to remove tar from relay board?
rwilner
post Apr 12 2012, 12:44 PM
No Ghosts in the Machine
I did a search and found a few threads, but I'm having kind of a hard time getting all the tar off the underside of the relay board to a clean surface.
I was able to chip a lot out. Then I tried a heat gun which really just turned it into goo -- didn't make it easier to remove. Then i soaked it in mineral spirits, which kind of gummed it up...I was hoping it would dissolve it.
How can I get the underside pristine? Other chemicals (isopropyl alcohol)? Some kind of media blast?
Valy
post Apr 13 2012, 12:14 PM
QUOTE(rwilner @ Apr 12 2012, 11:44 AM) *
Rich, if you can melt the tar with the heat gun, you already resealed it.
I know you're trying to get it of and I assume you want to recover the board. But if you can just reseal it then I think you're done (IMG:style_emoticons/default/confused24.gif)
rwilner
post Apr 13 2012, 12:16 PM
QUOTE(Valy @ Apr 13 2012, 02:14 PM) *
I'm trying to remove it so I can solder the rivets and fix a couple of non conducting traces.
Valy
post Apr 13 2012, 12:54 PM
QUOTE(rwilner @ Apr 13 2012, 11:16 AM) *
Hugh (IMG:style_emoticons/default/blink.gif)
I didn't know those boards can get so bad. I just thrown away a spare board I had that had all the tar fallen off but the copper traces were fine. The traces are quite thick so brakes in them means they are really gone.
I think I have another nice board somewhere. I'm not sure if there are differences between early/late/djet/ljet and not sure which one I have anyway. PM me if you need it and I'll try to dig it up.
- Lo-Fi Version Time is now: 8th November 2026 - 12:22 AM
