> '72 2.4 911e into 914-4, any wiring experience appreciated
martin_UK914
post Apr 10 2012, 06:41 AM
Morning!
So have a 1972 2.4 911E einsprizung motor going into a 1970 914-4 2.0L which had fully functioning injection.
All oil tank pipe etc sorted thanks to advice given on here... now just to connect electrics...
Anyone got any diagrams / advice / existing threads....
cheers.
Martin
IronHillRestorations
post Apr 13 2012, 08:58 PM
I. I. R. C.
If you've got 914-6 heat exchangers, you can weld a tube and run a hose to the thermostat on the injection pump. You HAVE to get hot air to the t-stat or the pump will never work right. I've never seen the Supertech set up, but it sounds like a good idea for a car without heaters.
shuie
post Apr 13 2012, 09:44 PM
QUOTE(9146986 @ Apr 13 2012, 06:58 PM) *
There is also a relay for the cold start injection contraption in the 911 engine relay panel. I promise you the car will not start easily if the cold start injection is missing or disabled. I removed this panel from my '72 911 when I did my 3.2 swap, but if I were ever to put a 2.4 MFI motor into a car I would definitely want to keep it. You are going to need the external voltage regulator, 3 pin CD box, and all of the little MFI bits either accounted for and in good working order, or properly substituted for with things like the Supertech kit. Adjusting the MFI in a 914 is really going to be tough, too, which is probably why the factory used carbs on the -6. Here's the 2.4 MFI 911 relay panel for reference.
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-2075-1334375041.1.jpg)
ClayPerrine
post Apr 14 2012, 05:17 AM
QUOTE(shuie @ Apr 13 2012, 10:44 PM) *
Acutally, from experience, it is much easier. You can get to the pump, and you don't have to go through the fan. Just a short, small flathead screwdriver.
And the factory used carbs on the -6 because it was cheaper and they didn't want the 914 out performing their flagship 911.
martin_UK914   '72 2.4 911e into 914-4   Apr 10 2012, 06:41 AM
martin_UK914   oh... and its a euro engine, so I don't think ...   Apr 10 2012, 06:42 AM
ClayPerrine   You are going to have to make an adapter wiring ha...   Apr 10 2012, 07:50 AM
J P Stein   I did a 2.4L conversion in my pre-Internet days......   Apr 10 2012, 09:37 AM
9146986   You'll need to have the RPM transducer, and th...   Apr 10 2012, 08:18 PM
GeorgeRud   auto Atlanta has a nice booklet with electrical co...   Apr 10 2012, 08:22 PM
plays with cars   auto Atlanta has a nice booklet with electrical c...   Apr 12 2012, 12:11 AM
9146986   The AA book doesn't cover MFI. You'll als...   Apr 12 2012, 07:13 AM
ClayPerrine   The AA book doesn't cover MFI. You'll al...   Apr 13 2012, 11:41 AM
Series9   MFI isn't electrically complicated. Sit down ...   Apr 13 2012, 11:46 AM
9146986   If you've got 914-6 heat exchangers, you can w...   Apr 13 2012, 08:58 PM
shuie   If you've got 914-6 heat exchangers, you can ...   Apr 13 2012, 09:44 PM
ClayPerrine   Adjusting the MFI in a 914 is really going to be...   Apr 14 2012, 05:17 AM
9146986   In the "FWIW Department" some of the 916...   Apr 14 2012, 06:13 AM
jm993rs   I will some have the same questions for the conver...   Apr 14 2012, 07:07 AM
jm993rs   the pics of my 914 6 gt clone !!! :dr...   Apr 14 2012, 07:17 AM
brp986s   :shocked: :worship: That car is going to be too f...   Apr 14 2012, 09:01 AM
jm993rs   :beer2: yes ||| the island is very little but ha...   Apr 15 2012, 01:23 PM
jm993rs   Our for make the conversion need your viewpoint, p...   Apr 17 2012, 03:39 AM
jm993rs   Please anybody can give your view point and instru...   Jun 27 2012, 04:01 AM
- Lo-Fi Version Time is now: 29th October 2026 - 11:35 PM
