| Black22 |
Apr 15 2012, 03:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
I have a new 1911 with L-jet. It was formerly a 1.8L stock engine that ran good. Trying to do the break in cycle but have no fuel.
I have spark and air, but injectors won't fire. I can however jump the relay and get the fuel pump to run. I can also move the flap manually at the AFM and that will also trigger the pump to run with all the stock wiring in place. I tried all the tests at the manuals.type4.org website. It passes all the tests. Only one test is questionable though. ** Measure the resistance between ECU plug terminal 20 and system ground at terminal 17. The reading should be 52-78 Ohms. Mine reads 5.9 Ohms. That would suggest the dual relay is bad, so I install a brand new relay and that one reads 6.9 Ohms. WTH? What am I missing? |
| Dave_Darling |
Apr 16 2012, 09:25 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
No trigger points in L-jet. It goes off the ignition signal.
Speaking of which: All the wires connected? There should be an "extra" one on the coil to pick up the ignition signal for the injection. How's the dual relay doing? --DD |
Black22 Won't Fire up with L-jet Apr 15 2012, 03:47 PM
pilothyer The L-Jet system doesn't pressurize the fuel l... Apr 15 2012, 03:52 PM
Black22 Alright, I checked it out a little more after the ... Apr 15 2012, 10:18 PM
falconfp2001
Alright, I checked it out a little more after the... Apr 15 2012, 10:56 PM
falconfp2001
Alright, I checked it out a little more after th... Apr 16 2012, 12:04 AM
CrashDown Youve got waaaay more patience then me for that st... Apr 15 2012, 10:59 PM
76-914
Youve got waaaay more patience then me for that s... Apr 16 2012, 12:25 PM
Black22
No trigger points in L-jet. It goes off the igni... Apr 16 2012, 11:00 AM
pt_700 while not l-jet, my 1.7 had the same issue - no si... Apr 16 2012, 01:40 PM
Black22 I saw an ad in the classifieds for and ECU.
Do th... Apr 16 2012, 02:00 PM
pt_700 i'd search around as i seem to recal seeing a ... Apr 16 2012, 03:19 PM
tim_nd Mine didn't start up at first. Same issues yo... Apr 16 2012, 02:11 PM
Black22
Mine didn't start up at first. Same issues y... Apr 16 2012, 02:58 PM
tim_nd I believe you, I'm sure the dbl relay is good.... Apr 16 2012, 03:05 PM
tim_nd 2 more silly questions. Is the yellow wire attach... Apr 16 2012, 03:41 PM
Black22
2 more silly questions. Is the yellow wire attac... Apr 16 2012, 03:50 PM
pilothyer Have you checked the temp sensor? Do you have a w... Apr 16 2012, 04:08 PM
Black22
Have you checked the temp sensor? Do you have a ... Apr 16 2012, 04:54 PM
tim_nd You have fuel pump action, while depressing the AF... Apr 16 2012, 05:04 PM
Black22
You have fuel pump action, while depressing the A... Apr 16 2012, 05:51 PM
pilothyer You can determine if the pump is running with the ... Apr 16 2012, 07:25 PM
Black22
You can determine if the pump is running with the... Apr 16 2012, 08:09 PM
pilothyer
You can determine if the pump is running with th... Apr 16 2012, 09:23 PM
tim_nd
[quote name='Black22' post='1667731' date='Apr 16... Apr 16 2012, 09:46 PM
Black22
[quote name='Black22' post='1667731' date='Apr 1... Apr 16 2012, 09:59 PM
Black22
Cool, good to know that. He has already stated ... Apr 17 2012, 10:02 PM
Black22
[quote name='pilothyer' post='166768... Apr 16 2012, 09:55 PM
tim_nd Correct operation of the double relay would be zer... Apr 16 2012, 08:24 PM
Black22 Thanks, I'll have to test it again.
I have th... Apr 16 2012, 08:30 PM
Black22 Sorry! My quote separating didn't go as pl... Apr 16 2012, 09:56 PM
tim_nd Good to hear that you have voltage at 88b. Now ch... Apr 16 2012, 10:03 PM
Black22
Good to hear that you have voltage at 88b. Now c... Apr 16 2012, 10:07 PM
tim_nd Cool, that sounds great.
Now check pins 14 to gnd... Apr 17 2012, 10:16 PM
Black22 Alright....where to continue from?
1911 with L-je... Apr 22 2012, 02:16 PM
914itis Deleted Apr 22 2012, 02:22 PM
dlee6204 L-Jet doesn't have trigger points Apr 22 2012, 02:23 PM
dlee6204 You should only have 12V to 88c when the engine is... Apr 22 2012, 02:26 PM
Black22 Doug, I don't have that ground wire in your la... Apr 22 2012, 02:30 PM
dlee6204
Um, not sure :confused: Its been a while since I... Apr 22 2012, 02:35 PM
dlee6204 I skimmed through the rest of this thread but if I... Apr 22 2012, 02:39 PM
Black22 3 NOS injectors 1 that was previously on engine ru... Apr 22 2012, 02:45 PM
pilothyer
3 NOS injectors 1 that was previously on engine r... Apr 22 2012, 05:47 PM
Tom Mike,
How many wires do you have going into the... Apr 22 2012, 02:56 PM
jim_hoyland The dual relay has a brown ground wire. Usually at... Apr 22 2012, 03:07 PM
Black22
The dual relay has a brown ground wire. Usually a... Apr 22 2012, 03:11 PM
Black22 6 wires. One at each terminal listed on the diagra... Apr 22 2012, 03:10 PM
Tom I admit that I don't know L-jet.
I see you ha... Apr 22 2012, 03:27 PM
Black22
I see you h... Apr 22 2012, 03:37 PM
dlee6204
Doug, I don't have that ground wire in your l... Apr 22 2012, 03:29 PM
Black22
[quote name='Black22' post='1671369' date='Apr 22... Apr 22 2012, 03:38 PM
dlee6204 Well I'm out. It seems like you've alread... Apr 22 2012, 04:05 PM
Black22
Well I'm out. It seems like you've alrea... Apr 22 2012, 04:10 PM
jim_hoyland IIRC you can circumvent the dual relay by groundin... Apr 22 2012, 04:11 PM
kg6dxn Need a L jet manual?
https://docs.google.com/file/... Apr 22 2012, 04:37 PM
pilothyer Mike....I had this identical problem with my 75 1.... Apr 22 2012, 05:29 PM
tim_nd Check the resistance on the ECU plug between pin 1... Apr 22 2012, 06:07 PM
Valy I would check
1. Does the injector get a pulse?
i... Apr 22 2012, 06:22 PM
Tom Mike,
Reading over your thread again, it sure s... Apr 23 2012, 10:18 AM
ClayPerrine My suggestion.
There is a white wire in the L-Je... Apr 23 2012, 10:30 AM
Black22
My suggestion.
There is a white wire in the L-J... Apr 23 2012, 11:56 AM
Cupomeat Sorry you are having this much problem with L-Jet,... Apr 23 2012, 11:54 AM
Tom I can tell you are really frustrated! Been th... Apr 23 2012, 12:25 PM
Black22
I can tell you are really frustrated! Been t... Apr 23 2012, 01:19 PM
jim_hoyland :popcorn:
Any progress ? Apr 23 2012, 05:18 PM
Black22
:popcorn:
Any progress ?
Didn't get to it... Apr 23 2012, 07:46 PM
Qarl Don't give up. You will get it... And in the ... Apr 23 2012, 08:17 PM
Black22
Don't give up. You will get it... And in the... Apr 23 2012, 08:57 PM
ClayPerrine Get one of these : Noid Light
Plug it into your... Apr 24 2012, 02:21 PM
dlee6204 Bump :boing:
Did you ever find the issue and g... May 20 2012, 06:01 AM
Black22 Sorry to leave everyone in suspense. It is running... May 20 2012, 09:03 AM
dlee6204 :Qarl: :trophy: May 20 2012, 09:21 AM
Tom So glad to hear this Mike.
I have found many tim... May 20 2012, 01:36 PM
Jaydebeers Have a Double relay question. Trouble shot no curr... Dec 7 2015, 10:58 AM
76-914
Have a Double relay question. Trouble shot no cur... Dec 7 2015, 01:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:52 AM |
