| Black22 |
Apr 15 2012, 03:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
I have a new 1911 with L-jet. It was formerly a 1.8L stock engine that ran good. Trying to do the break in cycle but have no fuel.
I have spark and air, but injectors won't fire. I can however jump the relay and get the fuel pump to run. I can also move the flap manually at the AFM and that will also trigger the pump to run with all the stock wiring in place. I tried all the tests at the manuals.type4.org website. It passes all the tests. Only one test is questionable though. ** Measure the resistance between ECU plug terminal 20 and system ground at terminal 17. The reading should be 52-78 Ohms. Mine reads 5.9 Ohms. That would suggest the dual relay is bad, so I install a brand new relay and that one reads 6.9 Ohms. WTH? What am I missing? |
| Black22 |
Apr 22 2012, 02:16 PM
Alright....where to continue from?
1911 with L-jet. Yet to break in. Harnesses gone through...every contact checks good. AFM: ohms out good New Double relay Rebuilt ECU I've gone through everything at manuals.type4.org. and all but one items checks out. It says I should have 12v from ground(pin85 on dbl relay) to pin 88c on dbl relay. I have 0 volts. This is a NEW relay. (IMG:style_emoticons/default/WTF.gif) Pump runs with AFM flap manually moved and while cranking engine over. Every wire is accounted for and hooked up properly. Engine will start if starter fluid or gas is squirted into throttle body. Everything check except my injectors will not fire. I have jumped from ground to pins 14,15,32 & 33 and can hear each injector click. tim_nd has spent alot of time with this on me and we cannot get it figured out. PLEASE!!! Anyone else have any ideas? Would a bad relay board cause this? |
Black22 Won't Fire up with L-jet Apr 15 2012, 03:47 PM
pilothyer The L-Jet system doesn't pressurize the fuel l... Apr 15 2012, 03:52 PM
Black22 Alright, I checked it out a little more after the ... Apr 15 2012, 10:18 PM
falconfp2001
Alright, I checked it out a little more after the... Apr 15 2012, 10:56 PM
falconfp2001
Alright, I checked it out a little more after th... Apr 16 2012, 12:04 AM
CrashDown Youve got waaaay more patience then me for that st... Apr 15 2012, 10:59 PM
76-914
Youve got waaaay more patience then me for that s... Apr 16 2012, 12:25 PM
Dave_Darling No trigger points in L-jet. It goes off the ignit... Apr 16 2012, 09:25 AM
Black22
No trigger points in L-jet. It goes off the igni... Apr 16 2012, 11:00 AM
pt_700 while not l-jet, my 1.7 had the same issue - no si... Apr 16 2012, 01:40 PM
Black22 I saw an ad in the classifieds for and ECU.
Do th... Apr 16 2012, 02:00 PM
pt_700 i'd search around as i seem to recal seeing a ... Apr 16 2012, 03:19 PM
tim_nd Mine didn't start up at first. Same issues yo... Apr 16 2012, 02:11 PM
Black22
Mine didn't start up at first. Same issues y... Apr 16 2012, 02:58 PM
tim_nd I believe you, I'm sure the dbl relay is good.... Apr 16 2012, 03:05 PM
tim_nd 2 more silly questions. Is the yellow wire attach... Apr 16 2012, 03:41 PM
Black22
2 more silly questions. Is the yellow wire attac... Apr 16 2012, 03:50 PM
pilothyer Have you checked the temp sensor? Do you have a w... Apr 16 2012, 04:08 PM
Black22
Have you checked the temp sensor? Do you have a ... Apr 16 2012, 04:54 PM
tim_nd You have fuel pump action, while depressing the AF... Apr 16 2012, 05:04 PM
Black22
You have fuel pump action, while depressing the A... Apr 16 2012, 05:51 PM
pilothyer You can determine if the pump is running with the ... Apr 16 2012, 07:25 PM
Black22
You can determine if the pump is running with the... Apr 16 2012, 08:09 PM
pilothyer
You can determine if the pump is running with th... Apr 16 2012, 09:23 PM
tim_nd
[quote name='Black22' post='1667731' date='Apr 16... Apr 16 2012, 09:46 PM
Black22
[quote name='Black22' post='1667731' date='Apr 1... Apr 16 2012, 09:59 PM
Black22
Cool, good to know that. He has already stated ... Apr 17 2012, 10:02 PM
Black22
[quote name='pilothyer' post='166768... Apr 16 2012, 09:55 PM
tim_nd Correct operation of the double relay would be zer... Apr 16 2012, 08:24 PM
Black22 Thanks, I'll have to test it again.
I have th... Apr 16 2012, 08:30 PM
Black22 Sorry! My quote separating didn't go as pl... Apr 16 2012, 09:56 PM
tim_nd Good to hear that you have voltage at 88b. Now ch... Apr 16 2012, 10:03 PM
Black22
Good to hear that you have voltage at 88b. Now c... Apr 16 2012, 10:07 PM
tim_nd Cool, that sounds great.
Now check pins 14 to gnd... Apr 17 2012, 10:16 PM
914itis Deleted Apr 22 2012, 02:22 PM
dlee6204 L-Jet doesn't have trigger points Apr 22 2012, 02:23 PM
dlee6204 You should only have 12V to 88c when the engine is... Apr 22 2012, 02:26 PM
Black22 Doug, I don't have that ground wire in your la... Apr 22 2012, 02:30 PM
dlee6204
Um, not sure :confused: Its been a while since I... Apr 22 2012, 02:35 PM
dlee6204 I skimmed through the rest of this thread but if I... Apr 22 2012, 02:39 PM
Black22 3 NOS injectors 1 that was previously on engine ru... Apr 22 2012, 02:45 PM
pilothyer
3 NOS injectors 1 that was previously on engine r... Apr 22 2012, 05:47 PM
Tom Mike,
How many wires do you have going into the... Apr 22 2012, 02:56 PM
jim_hoyland The dual relay has a brown ground wire. Usually at... Apr 22 2012, 03:07 PM
Black22
The dual relay has a brown ground wire. Usually a... Apr 22 2012, 03:11 PM
Black22 6 wires. One at each terminal listed on the diagra... Apr 22 2012, 03:10 PM
Tom I admit that I don't know L-jet.
I see you ha... Apr 22 2012, 03:27 PM
Black22
I see you h... Apr 22 2012, 03:37 PM
dlee6204
Doug, I don't have that ground wire in your l... Apr 22 2012, 03:29 PM
Black22
[quote name='Black22' post='1671369' date='Apr 22... Apr 22 2012, 03:38 PM
dlee6204 Well I'm out. It seems like you've alread... Apr 22 2012, 04:05 PM
Black22
Well I'm out. It seems like you've alrea... Apr 22 2012, 04:10 PM
jim_hoyland IIRC you can circumvent the dual relay by groundin... Apr 22 2012, 04:11 PM
kg6dxn Need a L jet manual?
https://docs.google.com/file/... Apr 22 2012, 04:37 PM
pilothyer Mike....I had this identical problem with my 75 1.... Apr 22 2012, 05:29 PM
tim_nd Check the resistance on the ECU plug between pin 1... Apr 22 2012, 06:07 PM
Valy I would check
1. Does the injector get a pulse?
i... Apr 22 2012, 06:22 PM
Tom Mike,
Reading over your thread again, it sure s... Apr 23 2012, 10:18 AM
ClayPerrine My suggestion.
There is a white wire in the L-Je... Apr 23 2012, 10:30 AM
Black22
My suggestion.
There is a white wire in the L-J... Apr 23 2012, 11:56 AM
Cupomeat Sorry you are having this much problem with L-Jet,... Apr 23 2012, 11:54 AM
Tom I can tell you are really frustrated! Been th... Apr 23 2012, 12:25 PM
Black22
I can tell you are really frustrated! Been t... Apr 23 2012, 01:19 PM
jim_hoyland :popcorn:
Any progress ? Apr 23 2012, 05:18 PM
Black22
:popcorn:
Any progress ?
Didn't get to it... Apr 23 2012, 07:46 PM
Qarl Don't give up. You will get it... And in the ... Apr 23 2012, 08:17 PM
Black22
Don't give up. You will get it... And in the... Apr 23 2012, 08:57 PM
ClayPerrine Get one of these : Noid Light
Plug it into your... Apr 24 2012, 02:21 PM
dlee6204 Bump :boing:
Did you ever find the issue and g... May 20 2012, 06:01 AM
Black22 Sorry to leave everyone in suspense. It is running... May 20 2012, 09:03 AM
dlee6204 :Qarl: :trophy: May 20 2012, 09:21 AM
Tom So glad to hear this Mike.
I have found many tim... May 20 2012, 01:36 PM
Jaydebeers Have a Double relay question. Trouble shot no curr... Dec 7 2015, 10:58 AM
76-914
Have a Double relay question. Trouble shot no cur... Dec 7 2015, 01:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:58 AM |
