> Won't Fire up with L-jet, WTF!!! Update on Page 2 post 35
Black22
post Apr 15 2012, 03:47 PM
I have a new 1911 with L-jet. It was formerly a 1.8L stock engine that ran good. Trying to do the break in cycle but have no fuel.
I have spark and air, but injectors won't fire.
I can however jump the relay and get the fuel pump to run. I can also move the flap manually at the AFM and that will also trigger the pump to run with all the stock wiring in place.
I tried all the tests at the manuals.type4.org website. It passes all the tests.
Only one test is questionable though.
** Measure the resistance between ECU plug terminal 20 and system ground at terminal 17. The reading should be 52-78 Ohms. Mine reads 5.9 Ohms. That would suggest the dual relay is bad, so I install a brand new relay and that one reads 6.9 Ohms. WTH?
What am I missing?
Cupomeat
post Apr 23 2012, 11:54 AM
missing my NY 914 in VA
Sorry you are having this much problem with L-Jet, it sounds to me like you need to identify if the brain is providing an injector pulse as almost everything else is accounted for.
It is rare that these analog brains die, but it can happen.
When I put my L-jet back on (after a long time with dellortos) my only issues were fuel line leaks and a couple of bad (original) injectors.
Since then, it has proven to be a VERY reliable FI.
DON'T GIVE UP!!! (IMG:style_emoticons/default/cheer.gif)
Black22   Won't Fire up with L-jet   Apr 15 2012, 03:47 PM
pilothyer   The L-Jet system doesn't pressurize the fuel l...   Apr 15 2012, 03:52 PM
Black22   Alright, I checked it out a little more after the ...   Apr 15 2012, 10:18 PM
falconfp2001   Alright, I checked it out a little more after the...   Apr 15 2012, 10:56 PM
falconfp2001   Alright, I checked it out a little more after th...   Apr 16 2012, 12:04 AM
CrashDown   Youve got waaaay more patience then me for that st...   Apr 15 2012, 10:59 PM
76-914   Youve got waaaay more patience then me for that s...   Apr 16 2012, 12:25 PM
Dave_Darling   No trigger points in L-jet. It goes off the ignit...   Apr 16 2012, 09:25 AM
Black22   No trigger points in L-jet. It goes off the igni...   Apr 16 2012, 11:00 AM
pt_700   while not l-jet, my 1.7 had the same issue - no si...   Apr 16 2012, 01:40 PM
Black22   I saw an ad in the classifieds for and ECU. Do th...   Apr 16 2012, 02:00 PM
pt_700   i'd search around as i seem to recal seeing a ...   Apr 16 2012, 03:19 PM
tim_nd   Mine didn't start up at first. Same issues yo...   Apr 16 2012, 02:11 PM
Black22   Mine didn't start up at first. Same issues y...   Apr 16 2012, 02:58 PM
tim_nd   I believe you, I'm sure the dbl relay is good....   Apr 16 2012, 03:05 PM
tim_nd   2 more silly questions. Is the yellow wire attach...   Apr 16 2012, 03:41 PM
Black22   2 more silly questions. Is the yellow wire attac...   Apr 16 2012, 03:50 PM
pilothyer   Have you checked the temp sensor? Do you have a w...   Apr 16 2012, 04:08 PM
Black22   Have you checked the temp sensor? Do you have a ...   Apr 16 2012, 04:54 PM
tim_nd   You have fuel pump action, while depressing the AF...   Apr 16 2012, 05:04 PM
Black22   You have fuel pump action, while depressing the A...   Apr 16 2012, 05:51 PM
pilothyer   You can determine if the pump is running with the ...   Apr 16 2012, 07:25 PM
Black22   You can determine if the pump is running with the...   Apr 16 2012, 08:09 PM
pilothyer   You can determine if the pump is running with th...   Apr 16 2012, 09:23 PM
tim_nd   [quote name='Black22' post='1667731' date='Apr 16...   Apr 16 2012, 09:46 PM
Black22   [quote name='Black22' post='1667731' date='Apr 1...   Apr 16 2012, 09:59 PM
Black22   Cool, good to know that. He has already stated ...   Apr 17 2012, 10:02 PM
Black22   [quote name='pilothyer' post='166768...   Apr 16 2012, 09:55 PM
tim_nd   Correct operation of the double relay would be zer...   Apr 16 2012, 08:24 PM
Black22   Thanks, I'll have to test it again. I have th...   Apr 16 2012, 08:30 PM
Black22   Sorry! My quote separating didn't go as pl...   Apr 16 2012, 09:56 PM
tim_nd   Good to hear that you have voltage at 88b. Now ch...   Apr 16 2012, 10:03 PM
Black22   Good to hear that you have voltage at 88b. Now c...   Apr 16 2012, 10:07 PM
tim_nd   Cool, that sounds great. Now check pins 14 to gnd...   Apr 17 2012, 10:16 PM
Black22   Alright....where to continue from? 1911 with L-je...   Apr 22 2012, 02:16 PM
914itis   Deleted   Apr 22 2012, 02:22 PM
dlee6204   L-Jet doesn't have trigger points   Apr 22 2012, 02:23 PM
dlee6204   You should only have 12V to 88c when the engine is...   Apr 22 2012, 02:26 PM
Black22   Doug, I don't have that ground wire in your la...   Apr 22 2012, 02:30 PM
dlee6204   Um, not sure :confused: Its been a while since I...   Apr 22 2012, 02:35 PM
dlee6204   I skimmed through the rest of this thread but if I...   Apr 22 2012, 02:39 PM
Black22   3 NOS injectors 1 that was previously on engine ru...   Apr 22 2012, 02:45 PM
pilothyer   3 NOS injectors 1 that was previously on engine r...   Apr 22 2012, 05:47 PM
Tom   Mike, How many wires do you have going into the...   Apr 22 2012, 02:56 PM
jim_hoyland   The dual relay has a brown ground wire. Usually at...   Apr 22 2012, 03:07 PM
Black22   The dual relay has a brown ground wire. Usually a...   Apr 22 2012, 03:11 PM
Black22   6 wires. One at each terminal listed on the diagra...   Apr 22 2012, 03:10 PM
Tom   I admit that I don't know L-jet. I see you ha...   Apr 22 2012, 03:27 PM
Black22   I admit that I don't know L-jet. I see you h...   Apr 22 2012, 03:37 PM
dlee6204   Doug, I don't have that ground wire in your l...   Apr 22 2012, 03:29 PM
Black22   [quote name='Black22' post='1671369' date='Apr 22...   Apr 22 2012, 03:38 PM
dlee6204   Well I'm out. It seems like you've alread...   Apr 22 2012, 04:05 PM
Black22   Well I'm out. It seems like you've alrea...   Apr 22 2012, 04:10 PM
jim_hoyland   IIRC you can circumvent the dual relay by groundin...   Apr 22 2012, 04:11 PM
kg6dxn   Need a L jet manual? https://docs.google.com/file/...   Apr 22 2012, 04:37 PM
pilothyer   Mike....I had this identical problem with my 75 1....   Apr 22 2012, 05:29 PM
tim_nd   Check the resistance on the ECU plug between pin 1...   Apr 22 2012, 06:07 PM
Valy   I would check 1. Does the injector get a pulse? i...   Apr 22 2012, 06:22 PM
Tom   Mike, Reading over your thread again, it sure s...   Apr 23 2012, 10:18 AM
ClayPerrine   My suggestion. There is a white wire in the L-Je...   Apr 23 2012, 10:30 AM
Black22   My suggestion. There is a white wire in the L-J...   Apr 23 2012, 11:56 AM
Cupomeat   Sorry you are having this much problem with L-Jet,...   Apr 23 2012, 11:54 AM
Tom   I can tell you are really frustrated! Been th...   Apr 23 2012, 12:25 PM
Black22   I can tell you are really frustrated! Been t...   Apr 23 2012, 01:19 PM
jim_hoyland   :popcorn: Any progress ?   Apr 23 2012, 05:18 PM
Black22   :popcorn: Any progress ? Didn't get to it...   Apr 23 2012, 07:46 PM
Qarl   Don't give up. You will get it... And in the ...   Apr 23 2012, 08:17 PM
Black22   Don't give up. You will get it... And in the...   Apr 23 2012, 08:57 PM
ClayPerrine   Get one of these : Noid Light Plug it into your...   Apr 24 2012, 02:21 PM
dlee6204   Bump :boing: Did you ever find the issue and g...   May 20 2012, 06:01 AM
Black22   Sorry to leave everyone in suspense. It is running...   May 20 2012, 09:03 AM
dlee6204   :Qarl: :trophy:   May 20 2012, 09:21 AM
Tom   So glad to hear this Mike. I have found many tim...   May 20 2012, 01:36 PM
Jaydebeers   Have a Double relay question. Trouble shot no curr...   Dec 7 2015, 10:58 AM
76-914   Have a Double relay question. Trouble shot no cur...   Dec 7 2015, 01:53 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:37 PM
