Tranny Bellcrank for /6 conversion..Help needed, Will this work? |
phillstek |
May 18 2012, 06:54 AM
Member Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
I need to make a bellcrank and came up with this crude drawing/design. Pretty sure the bottom lever is right but not sure if the top one is.
Any of you engineer types able to critique? Will it work? Feel free to laugh at my drawing Attached thumbnail(s) |
phillstek |
May 18 2012, 07:46 AM
Thanks chappy, problem is if I had one to copy then I wouldn't need to make one (not trying to be a smart arse). The one I had on my 901 box has a much longer bottom lever and totally different angles. I then got a hold of one for a 915 and while levers were shorter, the top one was too long this time and angles still not correct.
I thought the spring on the bottom lever would allow the use of lighter springs at the carbs thereby reducing the load on the throttle shafts (Webers)? Have searched here for more info but have not found any thing. |
Lo-Fi Version | Time is now: 11th June 2024 - 12:16 AM |
