| SchantzMD |
Mar 14 2012, 12:46 AM
Newbie ![]() Group: Members Posts: 33 Joined: 15-June 06 From: Riverside ca Member No.: 6,233 |
So I'm down to my last quarter at Cal Poly Pomona and the last thing I have to do to get my degree is finish one class and complete a Senior design project. Therefore over the next 12 weeks I'll be building a Physical Vapor Deposition (PVD) machine which will be capable of creating a very high vacuum, heating & vaporizing aluminum, and depositing it as a super shiny/reflective coating on a substrate.
In order to recoup some of my project cost (I've spent almost $2k already, damn this school thing is expensive! (IMG:style_emoticons/default/headbang.gif) ) I'm hoping to redo some fog light reflectors, front turn signal buckets, and maybe even some tail/brake/reverse light reflectors (Note: there may be a heat transfer issue on the rear reflectors since they're plastic, so I may not be able to coat them). So the question for you guys: Would you be interested in freshly coated reflectors for your lights and if so would $75-$100 for a reconditioned set seem reasonable? Keep in mind this will be dependent on being able to recreate a 98%-100% factory finish and that there will be a fair amount of material cost & prep time associated with each set of 2 reflectors done. Also, this will most likely have to be based on an "exchange" basis. To be honest I don't even know if I'll mess with this endevour yet or if I'll just sell the PVD machine when I'm done, so as of right now this is just a feeler. Thanks in advance for the input! Mike |
| Mr.242 |
May 20 2012, 08:27 AM
May your glass be smaller so it's always FULL! ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 10-June 08 From: Seattle Member No.: 9,160 Region Association: Pacific Northwest |
I also have to decide if I'm going to leave the reflectors coated or un-coated. If I don't coat them they will be 100% identical to the factory finish and will be completely fine if sealed with good lens gaskets, but if the gaskets leak the reflectors will be susceptible to oxidation and the coating will disintegrate if scrubbed clean (this is because the aluminum coating is only about 600 Angstroms thick). If I do top coat them with a clear coat the durability will increase, but the trade off is that the reflectivity properties may decrease.[u] I have to say...compared to the amount of reflectivity that a majority of us have RIGHT NOW, the reduced with a clear coat and the durability gained would be a monumental increase. I've got two sets and niether are much to jump up and down for joy. I would offer a set of donors to be done and understand that a clear over them would reduce. However, I also look at it as getting a set of "limited edition" models or 1st editions. Let me know if you need donors or volunteers as you work on experimental sets. I'll ship you my extra set. Knowing that it might not be up to final specs. (IMG:style_emoticons/default/pray.gif) MAY THE FORCE BE WITH YOU |
SchantzMD Anybody want Bright Lights? (Pics Added!) Mar 14 2012, 12:46 AM
71 sixer if you find that you are able to do the rear refle... Mar 14 2012, 03:59 AM
wingnut86 Share some pictures here of your PVD when done (no... Mar 14 2012, 05:24 AM
SchantzMD I'll definitely post a Youtube video because I... Mar 14 2012, 08:18 PM
Smitty911
I'll definitely post a Youtube video because ... Mar 14 2012, 10:45 PM
Mikey914 Mike make sure you put a clear over these. They wi... Mar 14 2012, 10:04 AM
Als914 Hey Mike, that is a great project :Qarl: . Hope yo... Mar 14 2012, 10:18 AM
7TPorsh Depending on price...front buckets and rear Mar 14 2012, 06:16 PM
matthepcat Good luck with the project! Make the most of t... Mar 14 2012, 09:45 PM
SchantzMD So after 250-300 hrs of work I finally have my PVD... May 16 2012, 08:20 PM
SchantzMD Thanks for all the interest guys!
Even thou... May 18 2012, 05:22 AM
Cairo94507 Wow - that looks incredible. You might have some ... May 16 2012, 08:33 PM
wingnut86 That's not funny. Take that glass orb back to... May 16 2012, 08:44 PM
SchantzMD Hey how'd you know that's where I got it f... May 18 2012, 05:26 AM
'73-914kid Mike, is that project here at CPP? If so, we'v... May 16 2012, 09:07 PM
SchantzMD Hey Ethan.
Actually no, but I do have it setup at... May 18 2012, 04:58 AM
76-914 That's cooler than an Eskimo fart. I hope it w... May 16 2012, 09:10 PM
Mr.242 Where does the line start? I would love to have s... May 16 2012, 10:55 PM
Porcharu I am most definitely interested in some 'new... May 16 2012, 11:03 PM
oldschool Boy I got to say....seems to be a bunch of you Cal... May 16 2012, 11:13 PM
rnellums Hot Damn! :headbanger: May 17 2012, 07:41 AM
RobW :headbanger: :headbanger: :headbanger: :headban... May 17 2012, 07:48 AM
GeorgeRud Sounds good to me! May 17 2012, 01:23 PM
bulitt Awesome :headbanger:
you need a DeLorean to mou... May 17 2012, 03:13 PM
zymurgist I'm in! :drooley: May 17 2012, 03:36 PM
Harpo I'm also in please let us know what you have i... May 17 2012, 03:47 PM
avidfanjpl Mike!
1. I would want one set of rear light b... May 17 2012, 07:29 PM
JRust Love to see some rear reflectors done! Great p... May 18 2012, 08:17 AM
'73-914kid
Hey Ethan.
Actually no, but I do have it setup a... May 18 2012, 08:31 AM
montoya 73 2.0 I'm interested as well. May 20 2012, 12:06 AM
euro911 Just saw this thread. Looks promising, Mike :thumb... May 20 2012, 01:08 AM
Howie's 914 I'm also interested. May 20 2012, 06:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th March 2026 - 01:29 AM |
