Porscharu914 |
Newbie ![]() Group: Members Posts: 20 Joined: 17-May 12 From: Denver, Colorado Member No.: 14,439 Region Association: Rocky Mountains ![]() |
Recently I was gifted a '71 914. This car was given to me by a member at the country club I work at. In 1983 he took the car to a shop in Nebraska where he paid a guy 4k to do a FULL restoration to the motor and body. ($4000.00 went slightly farther than it would today) The guy was supposed to work on the car on the weekends and they planned the project to take 18-24 months. After the motor/trans were pulled and the body work had been done the shop closed down and the car had to go....NOW. The guy I got the car from picked it up from the shop and stored it, mid restoration, in a garage thinking someday he'd get to it. The car hadn't been touched from then until last 2 Sundays ago and I'm now the proud owner of a primed, motorless, transmissionless, brakeless, and interiorless 914. With all the resources and personal abilities I have I should be able to flip the car in about 2 years....hopefully sooner.
Since the motor and transmission were pulled and mysteriously went 80% of the way missing I've decided to do the somewhat frowned upon Subaru swap. Yesterday I picked up the FWD transmission, yes FWD, out of a 92 Legacy. I'll be going back for an EJ22 (non turbo) on Monday. I'm not worried about mounting the motor/trans or getting CVs that will fit. I'm most concerned about doing an ALL AROUND hub conversion for the sake of saving some $$$ on brakes and the versatility of a wider wheel selection. So with the novel out of the way here are a few of my questions: What hubs will be the best bet for all 4 corners? (consistent bolt pattern is a must) Is plumbing in a front mounted radiator the most effective water cooling solution? Do I need to upgrade the fuel pump? If so, to how many lph? Is there an easy solution to making the Subie conversion work with my guage cluster? (tach, speedo.....etc) Are there any non-mechanical issues I'm up against for bolting everything together? Also I would very much appreciate any added advice or tips to make this a smooth conversion. Cheers |
Porscharu914 |
Picked up my Subaru Legacy 2.2 liter with 140,XXX miles on it for $275.00 yesterday. There's a $100 core charge but I'll get that back on Tuesday when I take them my 240sx motor I have sitting around. I also got a timing belt and reseal kit for the motor. That was another $240. I also found out that the intake plenum on the Subaru motors are reversible. (With minor bending of the fuel lines) I'm still only into this for about $650. (IMG:style_emoticons/default/smile.gif) I still need to get a starter, alternator, and PCM but those will probably come over the weekend or maybe Tuesday. Tuesday will also include mocking up the push/pull cable shifter system so I can order the cables and work on getting them mounted and working properly! I'm hoping to have the motor torn apart, cleaned, possibly painted, and resealed some day next week or early the following week. Making lots of good progress in the right direction!
Is anyone familiar with any companies that sell flat unmolded pieces of carpet that i can mold myself? (probably with a heat gun) Or anyone that sells new replacement carpet for the car? |
Lo-Fi Version | Time is now: 1st August 2025 - 03:07 AM |
