> Subaru Conversion, Helpful Hints
Porscharu914
post May 17 2012, 02:12 AM
Recently I was gifted a '71 914. This car was given to me by a member at the country club I work at. In 1983 he took the car to a shop in Nebraska where he paid a guy 4k to do a FULL restoration to the motor and body. ($4000.00 went slightly farther than it would today) The guy was supposed to work on the car on the weekends and they planned the project to take 18-24 months. After the motor/trans were pulled and the body work had been done the shop closed down and the car had to go....NOW. The guy I got the car from picked it up from the shop and stored it, mid restoration, in a garage thinking someday he'd get to it. The car hadn't been touched from then until last 2 Sundays ago and I'm now the proud owner of a primed, motorless, transmissionless, brakeless, and interiorless 914. With all the resources and personal abilities I have I should be able to flip the car in about 2 years....hopefully sooner.
Since the motor and transmission were pulled and mysteriously went 80% of the way missing I've decided to do the somewhat frowned upon Subaru swap. Yesterday I picked up the FWD transmission, yes FWD, out of a 92 Legacy. I'll be going back for an EJ22 (non turbo) on Monday. I'm not worried about mounting the motor/trans or getting CVs that will fit. I'm most concerned about doing an ALL AROUND hub conversion for the sake of saving some $$$ on brakes and the versatility of a wider wheel selection.
So with the novel out of the way here are a few of my questions:
What hubs will be the best bet for all 4 corners? (consistent bolt pattern is a must)
Is plumbing in a front mounted radiator the most effective water cooling solution?
Do I need to upgrade the fuel pump? If so, to how many lph?
Is there an easy solution to making the Subie conversion work with my guage cluster? (tach, speedo.....etc)
Are there any non-mechanical issues I'm up against for bolting everything together?
Also I would very much appreciate any added advice or tips to make this a smooth conversion.
Cheers
dlo914
post May 24 2012, 01:33 AM
Whatchu' lookin' at?!?!
the intake manifold is reversible, but then you would have to fabricate a new adjustable tensioning bracket for the alternator since the alternator still sits on the front side of the motor. We went through this entire situation with our EJ22 and resorted to cutting a 6x5" hole into the rear trunk to plumb the intake.
Porscharu914   Subaru Conversion   May 17 2012, 02:12 AM
wingnut86   :wttc: Education is key. Read all the blogs and...   May 17 2012, 07:00 AM
Lennies914   The answers to all your questions are here. Search...   May 17 2012, 07:34 AM
904svo   After putting a 2007 Subaru WRX in my kit car. I w...   May 17 2012, 08:18 AM
drdave427   After putting a 2007 Subaru WRX in my kit car. I ...   May 17 2012, 04:38 PM
904svo   After putting a 2007 Subaru WRX in my kit car. I...   May 17 2012, 05:33 PM
Dave_Darling   What hubs will be the best bet for all 4 corners? ...   May 17 2012, 06:08 PM
dlo914   VOX and i are also doing an EJ22 swap, but went wi...   May 18 2012, 12:39 PM
dlo914   Our cooling solution: dual core full aluminum radi...   May 18 2012, 12:49 PM
Dasnowman   Our cooling solution: dual core full aluminum rad...   May 24 2012, 02:25 AM
Porscharu914   Wow! Thanks for the warm welcome into the Pors...   May 18 2012, 05:08 PM
Porscharu914   I'm also in need of a pair of the side skirts....   May 18 2012, 05:10 PM
kg6dxn   Nice Score! :first: :wttc: Fix the rust fir...   May 18 2012, 06:13 PM
Lennies914   Nice Score! :first: :wttc: [u][b]Fix the r...   May 18 2012, 07:58 PM
Porscharu914   There's not one bit of rust on the car, the bo...   May 18 2012, 07:52 PM
pktzygt   I hope to fire my WRX swapped 914 in the next coup...   May 21 2012, 07:52 AM
Porscharu914   Picked up my Subaru Legacy 2.2 liter with 140,XXX ...   May 22 2012, 06:34 PM
wingnut86   Morph through his relationship with 914Rubber sell...   May 22 2012, 09:31 PM
dlo914   the intake manifold is reversible, but then you wo...   May 24 2012, 01:33 AM
Porscharu914   I decided that the inconvenience of having to plum...   May 24 2012, 01:43 AM
abnrdo   [quote name='dlo914' post='1677905' date='May 18 ...   Jun 3 2012, 12:34 AM
brant   Nice to see a denver guy on here we have a colora...   Jun 3 2012, 08:33 AM
Porscharu914   I'm definitely happy to see I'm not the on...   Jun 3 2012, 09:48 AM
brant   195 or 205 are going to fit fine with stock fender...   Jun 3 2012, 09:59 AM
Porscharu914   asdf   Dec 10 2012, 02:54 PM
dlo914   We got our 4x130 to 4x100 bolt pattern conversion ...   Dec 11 2012, 04:45 AM
Gint   Hey! I didn't see this thread last summer...   Dec 11 2012, 09:13 AM
Porscharu914   Hey! I didn't see this thread last summe...   Dec 12 2012, 03:29 PM
Porscharu914   I put a little bit of consideration into the mid m...   Dec 12 2012, 03:25 PM
FourBlades   Great project. :headbanger: Keep the pictures c...   Dec 12 2012, 03:39 PM
Porscharu914   Haven't posted in a while....a long while.... ...   Apr 18 2014, 02:25 AM
stimpyvan   <snip> ...started working on my cable shift...   Apr 18 2014, 08:31 AM
CptTripps   There was a thread not too long ago where a guy wa...   Apr 18 2014, 02:45 AM
76-914   Wondered where you went. Glad your back at it.   Apr 18 2014, 08:10 AM
JRust   Don't worry about a skid plate for the Gates h...   Apr 18 2014, 09:53 AM
Porscharu914   Finally getting into this project. In the last 2 w...   May 4 2014, 09:54 PM
CptTripps   That's great progress. Once you get all the ma...   May 6 2014, 07:43 AM
Porscharu914   Yesterday I picked up a new windshield. I paid ...   May 7 2014, 03:11 PM
malaga_red75   For the rear suspension, I would recommend Koni Ye...   May 7 2014, 07:14 PM
rnellums   Is there a reason that you don't want to get t...   May 7 2014, 09:00 PM
Porscharu914   Is there a reason that you don't want to get ...   May 8 2014, 04:35 PM
76-914   Word, my friend! Plus, they are now set up to ...   May 8 2014, 10:48 AM
Porscharu914   Brake rotors just showed up like I mentioned previ...   May 8 2014, 04:46 PM
Porscharu914   Fuel cell from Rhodes Racing, fans and legacy radi...   May 17 2014, 04:11 PM
Porscharu914   Sorry here's fuel cell fans and radiator. Also...   May 17 2014, 04:15 PM
- Lo-Fi Version Time is now: 1st August 2025 - 03:05 AM
