> New development regarding Subaru axles (group buy maybe?), I need opinions
IM101
post May 22 2012, 10:57 AM
For those who don’t know I’m starting to produce the items necessary for a Subaru conversion. I just got some prototype axles in from Sway-A-Way(SAW) and test fit them last night. While they fit both the older and newer style Subaru transmissions (different axle output style, male or female CV’s) as well as both the 914 and 944 CV’s I have stumbled onto a bit of a problem. The way Subaru designed the later/stronger 2005+ transmissions (with the male DOJ) the hub assembly must be removed to get the axles off. Translated to the 914, it makes installation/removal much more of a hassle than the earlier weaker transmissions.
What I need your opinion on is the viability of the SAW axles, originally at 375$ a set they were meant to be the most inexpensive/universal solution for the axle portion of the Subaru swap. Providing a cheaper alternative to the 600$+ the annoyance of needing to open the 2005+ box up and install the older style male stubs, that Subaru Gears offers. However now with the necessity of the male stubs for the Subaru transmission in the 914 it one of the advantages of the SAW system has been eliminated. It is still less expensive 375 (2004- trans) or 475 (w/stub for 2005+ trans) vs 500$ or 600$.
So anyone considering a “suborsche,” let me know what you think, is this something you would be interested in? I am ready to order 10 sets and they would be ready in 2 weeks, just pending your opinions on the matter.
Thanks
Ian M.
IM101
post May 24 2012, 01:37 AM
Wow Ian, that will be a stout transmission, the RA gearset is nice, cant wait to see some pictures. As to your question…
There are two options for the stronger 100mm joints. One is 944 stubs, cheap and easy to find used. However these require a spacer to work correctly. It would be easier, to find a set of 100mm 911 stub axles/ 75-79 I think, but pelican is listing the axle for a longer span...
75-85
The 911 100mm stub will fit perfectly, but you do need 944 joints, as I don’t know if the 100mm joint is the same 33 spline pattern. FYI here is a great write up Sir Andy did.
http://www.914world.com/bbs2/index.php?showtopic=59486
The only thing that would need to be changed to convert that to Subaru with my SAW axles is:
Subaru DOJ
SAW axle
944 100mm CV ->
911 ('75 - '79) 6-bolt 100mm stub axle ->
911 ('69 - '73?) hub
- Lo-Fi Version Time is now: 2nd April 2026 - 09:39 PM
