> 2056 Build
yeahmag
post Feb 2 2012, 12:49 AM
Installed crank, gears, cam, and rods. Dry fit CB's dry sump pump and modified the tang and clearanced drive tang boss.
yeahmag
post May 24 2012, 12:22 PM
OK. The long block is together and I'm starting on the valve train geometry. Here are some pic's:
The head after using Ajax to lap the cylinders
yeahmag   2056 Build   Feb 2 2012, 12:49 AM
RobW   Installed crank, gears, cam, and rods. Dry fit CB...   Feb 2 2012, 01:01 AM
ThePaintedMan   Cool! Wish I had the guts to attempt a rebuild...   Feb 2 2012, 06:43 AM
jaxdream   Will the fan housing bolt up / clear the new pump ...   Feb 2 2012, 09:06 AM
mrbubblehead   what are you going to do about your engine mounts?   Feb 2 2012, 09:52 AM
yeahmag   I will need to modify the fan housing to clear the...   Feb 2 2012, 10:46 AM
mrbubblehead   you are one step ahead of me. i am doing the same ...   Feb 2 2012, 03:55 PM
yeahmag   I ground about 2mm off that pump. Maybe more. I al...   Feb 2 2012, 04:01 PM
mrbubblehead   since im not using the stock oil cooler or stock o...   Feb 2 2012, 04:16 PM
yeahmag   How are you routing the oil for the pressure stage...   Feb 2 2012, 04:19 PM
mrbubblehead   i used this diagram http://www.914world.com/bbs2/u...   Feb 2 2012, 06:18 PM
Valy   i used this diagram http://www.914world.com/bbs2/...   Feb 2 2012, 11:20 PM
yeahmag   Here are pictures of the pistons after going throu...   Feb 2 2012, 09:41 PM
jmill   :agree: I was thinking the same thing. Somehow ...   Feb 3 2012, 07:07 PM
mrbubblehead   :agree: I was thinking the same thing. Somehow...   Feb 3 2012, 07:22 PM
Woody   You are going to love that engine. :Qarl: :beer2...   Feb 3 2012, 07:48 PM
mrbubblehead   any more progress yeahman? do you know what you ar...   Feb 4 2012, 04:18 PM
yeahmag   Been cleaning parts like mad. Finally ready to clo...   Feb 14 2012, 11:32 AM
yeahmag   OK. The long block is together and I'm startin...   May 24 2012, 12:22 PM
yeahmag   After the copper spray to help with the carbon s...   May 24 2012, 12:23 PM
yeahmag   Long block together (more or less).   May 24 2012, 12:24 PM
yeahmag   Ported the hell out of the CB Dry Sump Pump and ...   May 24 2012, 12:25 PM
Cupomeat   Ported the hell out of the CB Dry Sump Pump and...   Nov 27 2012, 09:44 AM
yeahmag   Shot of the heads with Jakes "super" o...   May 24 2012, 12:26 PM
Valy   Those studs look to short to me. And it looks to m...   May 24 2012, 01:39 PM
yeahmag   The nuts are just there to keep the rockers from f...   May 24 2012, 02:10 PM
yeahmag   Jake appears to like where I have my valve train g...   May 29 2012, 06:05 PM
yeahmag   Measuring my pushrod tips using a flat table and a...   Jun 6 2012, 12:19 PM
Valy   I would not measure them this way. Error is much h...   Jun 6 2012, 03:40 PM
yeahmag   Nah... The rig is designed for telescopes and is o...   Jun 6 2012, 04:14 PM
yeahmag   Here is a wider shot so you get a better feel for ...   Jun 6 2012, 04:16 PM
Valy   The cost of the measuring equipment doesn't be...   Jun 6 2012, 04:24 PM
yeahmag   I don't want to debat this too much, but this ...   Jun 6 2012, 04:42 PM
Valy   I don't want to debat this too much, but this...   Jun 6 2012, 05:39 PM
yeahmag   This weekend I finished my valve train. I ended up...   Jun 11 2012, 12:22 PM
yeahmag   While not quite part of the engine build I thought...   Aug 16 2012, 11:19 AM
yeahmag   It's been quite a while, but I have been worki...   Nov 5 2012, 11:47 AM
FourBlades   Cool engine build! :Qarl: John   Nov 5 2012, 12:30 PM
yeahmag   Forgot to show the port matching of the CB manifol...   Nov 5 2012, 04:59 PM
yeahmag   A few more... I have the scavenge line run up the ...   Nov 25 2012, 09:07 PM
yeahmag   RE: 2056 Build   Nov 25 2012, 09:08 PM
396   Cool engine build- oh thanks for the education too...   Nov 27 2012, 09:00 AM
yeahmag   Just the two lowers.   Nov 27 2012, 10:39 AM
yeahmag   Some craptastic iPhone photos of the progress. Pas...   Dec 11 2012, 06:04 PM
mrbubblehead   looks good. what size is that? -8, -10?   Dec 11 2012, 07:15 PM
yeahmag   -10 on the scavenge side. -12 for most of the run,...   Dec 11 2012, 07:31 PM
Gint   Nice! When do you fire it?   Dec 11 2012, 07:39 PM
pete-stevers   how did you bend the oil cooler?   Dec 11 2012, 11:20 PM
yeahmag   I bent the cooler in a press supporting it with 2x...   Dec 12 2012, 10:56 AM
914_teener   I bent the cooler in a press supporting it with 2...   Dec 14 2012, 02:22 PM
yeahmag   Soon they will be packed full of DOT-R rubber piec...   Dec 14 2012, 04:58 PM
yeahmag   Here are some pic's of my mock up of the tank,...   Jan 30 2013, 12:38 PM
mrbubblehead   nice yeamag. i did the same thing with the T fitti...   Jan 30 2013, 07:26 PM
yeahmag   Good idea! Not sure it has any higher probabil...   Jan 30 2013, 08:23 PM
mrbubblehead   your right. piece of mind i guess.   Jan 30 2013, 08:25 PM
yeahmag   And passenger side is finally done.   Feb 10 2013, 10:59 PM
mrbubblehead   looks good yeamag. those an fittings sure get expe...   Feb 10 2013, 11:35 PM
yeahmag   ...and yet more fittings to be ordered.   Feb 14 2013, 01:42 PM
mrbubblehead   that looks awesome bro. im glad summit has the ret...   Feb 14 2013, 02:43 PM
yeahmag   Got a little bit more done. Been thrashing for a f...   Feb 25 2013, 12:51 AM
yeahmag   Really just a matter of making it look good and pu...   Mar 4 2013, 10:53 PM
yeahmag   ...and if anybody has any words of wisdom how to p...   Mar 4 2013, 11:10 PM
mrbubblehead   good luck bro. sounds like a good plan. the only t...   Mar 4 2013, 11:55 PM
yeahmag   I've actually read more than once that filling...   Mar 5 2013, 12:50 AM
mrbubblehead   I've actually read more than once that fillin...   Mar 5 2013, 01:19 AM
yeahmag   Nope. I did remove the bypass and weld it shut in ...   Mar 5 2013, 10:20 AM
mrbubblehead   mine took alot of cranking to get the light to go ...   Mar 5 2013, 12:10 PM
Racer Chris   Aaron, Did you grease the gears in the pump to hel...   Mar 5 2013, 12:32 PM
yeahmag   No. I've had bad luck with that in the past wi...   Mar 5 2013, 12:37 PM
Racer Chris   I think the type of grease used is critical to tha...   Mar 5 2013, 12:51 PM
yeahmag   Knowing me I used wheel bearing grease and screwed...   Mar 5 2013, 12:53 PM
dfelz   I like your set up a lot, looks really good. are y...   Mar 5 2013, 05:36 PM
yeahmag   Yes. No cutting of the body.   Mar 5 2013, 05:46 PM
dfelz   Very cool, i saw you had a CB dry sump pump, are t...   Mar 5 2013, 06:09 PM
Racer Chris   ... a CB dry sump pump, are the aftermarket pumps...   Mar 5 2013, 08:04 PM
yeahmag   Just a quick update. Priming the system was no har...   Mar 11 2013, 09:59 AM
yeahmag   Drove it in to work yesterday and man did that fee...   Apr 3 2013, 11:07 AM
yeahmag   First long distance outing was driving to Cal Spee...   Apr 9 2013, 10:52 AM
yeahmag   Had some minor surgery on my throat last Monday, s...   Apr 24 2013, 09:17 PM
yeahmag   It did make a "squeak" that seemed to be...   Apr 24 2013, 09:24 PM
worn   It did make a "squeak" that seemed to b...   Apr 30 2013, 08:01 PM
- Lo-Fi Version Time is now: 24th October 2025 - 08:14 AM
