| 9fourteen |
May 23 2012, 10:34 AM
Newbie ![]() Group: Members Posts: 42 Joined: 20-November 06 From: Cincinnati, OH Member No.: 7,239 Region Association: Upper MidWest |
Before I start cutting into the longs and hell hole I was thinking about sand blasting the whole area first to see what I have and then prime it before making the repairs. (eventually I am going to strip the whole tub. just doing it in sections) I already bought a blaster from eastwood. Now I need to get setup for painting so I can prime it immediately after stripping it. I have made a list of the main things I need to buy. I think I got most of it figured out but have questions on the primer and a good paint gun. I have never sprayed paint so any advice is welcome or if there is something i need to add to my list, let me know.
Here is a list of what I think I will need paint gun etching primer fresh air respirator hood throw away coveralls gloves metal prep I am sure I will need stuff to mix the paint with. The paint shop guys will help with that. I am also going to build a chamber to limit the mess from the blasting and over spray in my garage. I went to the local paint shop and they sell three brands of etching primer, nason, ppg and dupont. They are in order of price. Nason appears to be a low priced dupont brand. It's about half the price. Can I use the cheap stuff or should I stick with the ppg or dupont. Obviously I want to save money but I don't have a problem buying the right stuff if it is worth it and will work better. Actual suggestion items numbers would be welcome. I was also looking at paint guns. They had a nice 2 gun set from DeVilbiss, one for priming, one for painting, i think it was around $200. They had other guns that were half the price or lower. I think i have read on here that the DeVilbiss guns are the best. (or at least in somebody's opinion they were). Is it worth the extra money or will I get the same results with the cheap gun? thanks I know everybody likes post with pictures so here is one. ![]() |
| scotty b |
May 24 2012, 05:04 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
For the most part yes. My problem is
a: there is nothing wrong with putting etch over the blasted surface. b: the reason I don;t use Eoxy is that it needs a rough surface to bond to and in the end it is simply a mechanical bond whereas the etch is a chemical bond. c: if you sand through the edge of eoxy, you can see it lifting at the break. I have actually broken through when sanding it and taken a blow chuck and blown ight on the edge and watched it start to lift on off. d: On the other hand , a good etch primer will breack through and have a nice featherd edge that won't lift. I use epoxy on things like suspension, or a car that is NOT getting a complete strip job as the bond between the old paint that I have sanded with 80 grit I then follow it up immediately with a spray poly so I get a chemical bond between the two of them, and the poly gets all of the sanding. |
9fourteen Etching Primer and Paint Gun? May 23 2012, 10:34 AM
Cairo94507 I like where this thread is heading. Good luck wi... May 23 2012, 01:19 PM
76-914 DuPont vari-prime is good shit. So good it can etc... May 23 2012, 01:31 PM
9fourteen
DuPont vari-prime is good shit. So good it can et... May 23 2012, 02:27 PM
scotty b you can spend a little more money and get either P... May 23 2012, 02:50 PM
9fourteen
you can spend a little more money and get either ... May 23 2012, 04:14 PM
9fourteen I have another question on the etching primer. If ... May 23 2012, 04:33 PM
rick 918-S I've posted this here before but I will mow th... May 23 2012, 06:34 PM
jmill My flares have been unpainted for over a year with... May 23 2012, 06:55 PM
9fourteen I was just reading on ppg's website about the ... May 24 2012, 06:37 AM
scotty b
I was just reading on ppg's website about the... May 24 2012, 07:42 AM
9fourteen
I was just reading on ppg's website about th... May 24 2012, 08:52 AM
scotty b For soda yes there is a bit of prep work. the soda... May 24 2012, 09:16 AM
9fourteen I stopped by the paint shop on my way home from wo... May 24 2012, 04:10 PM
914GT
I stopped by the paint shop on my way home from w... May 24 2012, 05:15 PM
9fourteen Here is what I ended up buying
I went with wha... Jun 1 2012, 07:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 06:17 AM |
