> Brake pedal randomly goes to floor
tornik550
post May 24 2012, 04:51 PM
I have not driven my car for a few years due to my engine rebuild. I bled my brakes. The brake pedal was hard when pressed however over the next day or so the pedal would creep down very slightly at red lights. I bled the brakes again however it did not help the problem. Now at stop lights sometimes the pedal is hard, sometimes it creeps all the way to the floor. Normally if the pedal starts to creep down, if I let off and reapply the brake, it will be firm- at least for a while.
-Does this sound like a master cylinder problem?
-I have searched and I do not see any brake fluid leaks.
-the brakes have been bled
-I am using stock 914-4 calipers with porterfield pads
- the rears have been properly clearanced
avidfanjpl
post May 24 2012, 05:57 PM
914 Hemophiliac
Yes, I had one leak on a car. Replace it with the 19MM, and the brakes feel better.
Lots go round and round on 17MM vs. 19MM
I have used both. Go with the 19MM and make sure you get new switches, at the pedal and in the MC. MC usually comes with that switch installed. One on the brakes is a separate part.
John
- Lo-Fi Version Time is now: 2nd November 2026 - 07:44 AM
