> 2.0 distributor questions..., 205AA dizzy with dual Webers
audio_file
post May 19 2012, 03:32 PM
I searched! I even tried to resurrect an old thread but it didn't get much attention, so I'll start another...
I bought a 205aa distributor (1974 1.8 dizzy) for my 2.0 with dual webers (it has an 009 now), and I'm not sure about the vacuum connections. The vacuum can on the 205 has two vac ports, as I understand it, one for advance and one for retard ( (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/biggrin.gif) ). What do I do with the retard side, use it or plug it? Where would the retard side plug into?
Will this operate as well as an SVDA (assuming both have petronix installed), or should I re-sell this 205 and pick one of those up instead?
Finally, do I need to use the vacuum from both carbs, or will one suffice?
TIA
Chris
r_towle
post May 27 2012, 08:49 AM
Custom Member
For advance, drill out the ports on the carbs for vacuum, tie them all together into a single line, then tie that to the advance port.
Don't use the retard port, leave it open and unplugged to the atmosphere.
Set timing at 3500 rims to ensure you are dealing with full advance when timing it.
You may need to mark your fan and housing, or use a newer timing light that can be programmed for 27 degrees advance.
The advance vacuum canister just brings on the advance sooner than the normal weights do it, so it's a smoother ramp up from a stop light..
Retard is purely for emissions and seeing as you have carbs, you are not worried about emissions.
Rich
audio_file   2.0 distributor questions...   May 19 2012, 03:32 PM
audio_file   Anyone? Bueller? Bueller? :bump:   May 20 2012, 01:29 PM
rhodyguy   i need to put a 205 in the green car. i tried 205 ...   May 27 2012, 07:58 AM
audio_file   i need to put a 205 in the green car. i tried 205...   May 27 2012, 08:10 AM
914itis   I don't think you need any vacuum for carbs. Y...   May 27 2012, 08:13 AM
rhodyguy   perfect. thanks paul. k   May 27 2012, 08:16 AM
audio_file   But, the car will run be more smoothly, and more e...   May 27 2012, 08:41 AM
r_towle   For advance, drill out the ports on the carbs for ...   May 27 2012, 08:49 AM
audio_file   For advance, drill out the ports on the carbs for...   May 27 2012, 09:00 AM
rhodyguy   where did you find the dif listing for the l-jet d...   May 27 2012, 09:28 AM
audio_file   where did you find the dif listing for the l-jet ...   May 27 2012, 09:42 AM
rhodyguy   wow!! cool chart. i don't know where y...   May 27 2012, 09:52 AM
audio_file   Found it here: (post 6) http://www.914world.com/bb...   May 27 2012, 10:17 AM
brant   I've owned about 6 sets of 4cylinder idf's...   May 27 2012, 10:31 AM
rhodyguy   none of the weber IDF series carbs i've owned ...   May 27 2012, 10:38 AM
audio_file   none of the weber IDF series carbs i've owned...   May 27 2012, 10:46 AM
rhodyguy   i just looked at some italian 40s. screws are ther...   May 27 2012, 10:56 AM
audio_file   Man I searched and searched before I started a new...   May 27 2012, 11:09 AM
r_towle   Some webers are drilled, some are not, all of them...   May 27 2012, 07:41 PM
Grelber   I have a 2.0L w/ Weber 40's and the 205D dizzy...   May 27 2012, 08:18 PM
audio_file   :bump: Today I finally yanked my old 009, points...   Jun 30 2012, 10:54 PM
anderssj   Wow, very timely thread! I have a 1.8 dizzy ...   Jul 1 2012, 09:18 AM
- Lo-Fi Version Time is now: 31st July 2025 - 12:59 PM
