Wiring up a stereo |
914Bryan |
May 27 2012, 08:20 AM
Member Group: Members Posts: 190 Joined: 6-June 11 From: Orange County Member No.: 13,162 Region Association: Southern California |
On a 74, what fuse would you run your hot lead from to power a stereo? Or would it be better to set up a dedicated, fused/switched lead directly from the battery?
My worry is when I add my stereo and an amp, I will be overtaxing the old system. Ideas? |
jsayre914 |
May 27 2012, 03:00 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I ran a line from the batteries directly to the HU and put a couple fuses down the line. I also wired both the switched and constant to a constant because my car is with electronic ignition and i am scared as hell to leave the key in the on position. I listen to music a lot with the car off. Amps need to run direct to the battery.
p.s. check out THIS THREAD for my build (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 10:35 AM |
