| scotty b |
May 27 2012, 06:29 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
I'm looking at borrowing some money and buying a new blasting setup. This is a new technology that generates no heat, works EXTREMELY qyuick and is ready for immediate priming. What I am trying to figure out is what a normal sand or soda blast job runs to do the complete exterior. If you are willing to post up what it cost you plese do. I'm thinking if I can get 3-4 jobs lined up I might be able to pay for this ting immediately depending on it's cost.
If you do post, please let me know what type of media was used and on what type of car. I'd like some ideas of what different sized cars run. A friend of mine had his 50 Ford body only done in soda for 1800.00. According to this website their setup would do that car in 2-3 hours total (IMG:style_emoticons/default/smile.gif) |
| Dr Evil |
May 28 2012, 12:14 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Soda is the only way to go. Better than nuts and way better than sand. Low heat, no mess.
I have heard quote for a 914 in soda in this area for $2k. |
| scotty b |
May 28 2012, 01:21 PM
Soda is the only way to go. Better than nuts and way better than sand. Low heat, no mess. I have heard quote for a 914 in soda in this area for $2k. Soda is total b.s. First off it won't do jack to rust or bondo, second, once the car is blasetd it needs to be washed and preferably sanded otherwise the primer will not stick to the car. This was first apparent in the airline industry when planes were being soda blasted and repainted and the paint started peeling off within a couple months. Most primers ( definitely the one I use ) have an acid in them to etch into the base metal, soda does not etch into the metal mechanically, and is a base substance ergo the two do not mix. I do not and will not use soda, I have personally seen it fail twice and both times was done by a business that speicialized in it. The process I am looking at is the new solution to soda. As I said, it generates zero heat, uses glass as the media, and leaves the surface ready for immediate priming. This process also has no dust, leaves no residue, and can be done within 10 feet of another car and will not harm or sully it in any way. (IMG:style_emoticons/default/smile.gif) Pending price this is THE best setup I have found |
| MDG |
May 28 2012, 04:29 PM
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,653 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
The process I am looking at is the new solution to soda. As I said, it generates zero heat, uses glass as the media, and leaves the surface ready for immediate priming. This process also has no dust, leaves no residue, and can be done within 10 feet of another car and will not harm or sully it in any way. (IMG:style_emoticons/default/smile.gif) Pending price this is THE best setup I have found (IMG:style_emoticons/default/smilie_pokal.gif) Sounds perfect. |
scotty b Blasting price question May 27 2012, 06:29 PM
MDG That would be a fantastic way to start a resto/rep... May 27 2012, 06:40 PM
mepstein I got 2 quotes for soda; 1 -mobile setup to your h... May 27 2012, 06:44 PM
r_towle Mobile soda, 356 tub, 500 bucks, two years ago
Tha... May 27 2012, 07:29 PM
cary Last year there was a stripped 911 tub at Rothspor... May 27 2012, 10:13 PM
914itis I was reading the thread here where the PO had my ... May 27 2012, 11:11 PM
OmaPossu Prices from Europe, 914 body shell with out doors ... May 28 2012, 06:28 AM
Series9 I had Nelson's car done by a mobile soda blast... May 28 2012, 06:30 AM
gopack I had my car soda blasted. they did the entire in... May 28 2012, 07:12 AM
balljoint My car blows sand out of the fresh air vents every... May 28 2012, 08:13 AM
scotty b
My car blows.
Please stay on subject Dave <_... May 28 2012, 09:47 AM
OU8AVW
My car blows.
Please stay on subject Dave ... May 28 2012, 12:40 PM
Mikey914 Had mine done locally for $350 with wallnut s... May 28 2012, 09:16 AM
PRS914-6 Scotty, I had mine done for about $1200 insid... May 28 2012, 09:46 AM
Dr Evil
Soda is the only way to go. Better than nuts and... May 28 2012, 02:36 PM
Bartlett 914
Soda is the only way to go. Better than nuts and... May 29 2012, 02:07 PM
PRS914-6 Scotty, I am sure you have seen most blasting tech... May 28 2012, 01:10 PM
mepstein I bet you could set up a 2nd business with this ne... May 28 2012, 02:12 PM
scotty b
I bet you could set up a 2nd business with this n... May 29 2012, 06:21 AM
Eric_Shea Love soda... :confused:
http://www.914world.com/b... May 28 2012, 06:14 PM
Dr Evil "Love soda"?
That just sounds gross. May 28 2012, 06:41 PM
Dr Evil I see that the soda revealed a gorilla face under ... May 28 2012, 06:47 PM
snakemain So when can I bring my car by? May 28 2012, 07:05 PM
Eric_Shea
We know you shouldn't weld. We're proba... May 29 2012, 12:27 AM
MDG
We know you shouldn't weld. We're prob... May 29 2012, 05:27 AM
Dr Evil
We know you shouldn't weld. We're pro... May 29 2012, 06:39 AM
effutuo101 800 including pick up and delivery for body and 4 ... May 29 2012, 01:58 PM
d914 soda about $1200
sand I have heard can be pr... May 29 2012, 02:07 PM
OU8AVW Gorilla? Um, did you guys notice the "other... May 29 2012, 02:35 PM
scotty b
Gorilla? Um, did you guys notice the "other... May 29 2012, 02:42 PM
MDG
That would explain Erc's personality issues ... May 29 2012, 04:21 PM
Dr Evil That dude hangs out outside of the 7-11 and asks f... May 29 2012, 02:47 PM
OU8AVW I was referring to the Savior's image, not the... May 29 2012, 02:47 PM
Dr Evil Penis???? May 29 2012, 02:54 PM
plas76targa attempting to wrestle this back on track for Scott... May 30 2012, 06:38 AM
Bartlett 914
attempting to wrestle this back on track for Scot... May 30 2012, 08:17 AM
scotty b
attempting to wrestle this back on track for Scot... May 30 2012, 12:08 PM
balljoint
attempting to wrestle this back on track for Sco... May 30 2012, 01:43 PM
MDG
Was this something you learned aboot at the Detro... May 30 2012, 02:34 PM
balljoint
Was this something you learned aboot at the Detr... May 30 2012, 07:13 PM
r_towle
[quote name='MDG' post='1684830' date='May 30 201... May 30 2012, 09:25 PM
Cairo94507 I am kind of interested here as my car is at Scott... May 30 2012, 06:47 AM
Katmanken Scotty,
Does the acidic material make yer car sme... May 30 2012, 05:22 PM
Vacca Rabite Let me know when you get this set up. I may bring ... May 30 2012, 07:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 07:33 PM |
