Early heater fan wiring question, with bonus mystery wire |
r3dplanet |
May 31 2012, 08:43 PM
Senior Member Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None |
My car has never had heat in the time that I've owned it. The car is a 1971 but the engine and wiring in the bay are all for 1973.
I took the time to completely refurb an early blower fan. It has two wires: one brown, one green. According to the wiring diagram I'm supposed to have wires directly from the harness to power it. I don't. Where am I supposed to tap for power? Also, on the relay board I have a mystery green wire coming from astern. I have no idea what it's for. Any guesses? See photos for clarity. Thanks, Marcus |
JeffBowlsby |
May 31 2012, 10:15 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Hi Marcus...so you're the Schpankmeister huh? (IMG:style_emoticons/default/wink.gif)
The ignition harnesses are not all the same...to correct any misinformation. See my harness website for details. There are 3 Djet ignition harnesses and 1 Ljet ignition harness for our 914s. They are each different. Issue: The 1970-72 cars main chassis harness does not have the wiring branch for the blower fan like the 1973-76 cars do. For the 1970-72 cars the fan connects to the ignition harness. For the 1973-76 cars the fan connects to a branch integral to the main chassis harness. Easiest solution? Use a 1970-72 ignition harness to use the heater fan for an early 914. The only other way I can think of off the top of my head is to use the 73-76 ignition harness, then find the correct pin on the 12 pin connector for the (its either 10 or 11) for the green wire, then run a separate ground wire for the fan. You can study the two ignition harness diagrams and see what I am talking about. Or I can make a new or customize your existing harness to do the trick. |
r3dplanet |
May 31 2012, 10:52 PM
Hi Marcus...so you're the Schpankmeister huh? (IMG:style_emoticons/default/wink.gif) The ignition harnesses are not all the same...to correct any misinformation. See my harness website for details. There are 3 Djet ignition harnesses and 1 Ljet ignition harness for our 914s. They are each different. Issue: The 1970-72 cars main chassis harness does not have the wiring branch for the blower fan like the 1973-76 cars do. For the 1970-72 cars the fan connects to the ignition harness. For the 1973-76 cars the fan connects to a branch integral to the main chassis harness. Easiest solution? Use a 1970-72 ignition harness to use the heater fan for an early 914. The only other way I can think of off the top of my head is to use the 73-76 ignition harness, then find the correct pin on the 12 pin connector for the (its either 10 or 11) for the green wire, then run a separate ground wire for the fan. You can study the two ignition harness diagrams and see what I am talking about. Or I can make a new or customize your existing harness to do the trick. Ack. It used to be that the Spankmeister thing was just born from irritation because all the other names I could think of were taken. Since then I've been using r3dplanet, but I can't change the name here. I'm stuck. And I'm not even into spanking. Let me announce that I've made a blunder. In fact, I believed all the harnesses I bought from you were in fact ordered for a 1971 model. The relay panel is still from 1973. I didn't know that my engine was a '73 until I was installing the harnesses this spring when I discovered that the harness came with a different throttle position pinout. When I looked at the engine code I discovered I had an EA engine - or 1973 1.7 liter. So scratch all that information about having all 1973 wiring. The only '73 wiring I have is the relay board and injection harness. If the early ignition harness provides connections to the fan, then I'm even more confused because I don't see any connections. This leaves me thinking that since I ordered the ignition harness a month after the purchase of the injection harness (when I made the EA engine discovery) I must have then ordered a '73 ignition harness. Thus, I have no fan connection at all because I have a late ignition harness (with no fan connection) and an early chassis harness that doesn't provide the connections either. I apologize for the misinformation. It must be the new meds. -marcus |
Lo-Fi Version | Time is now: 8th June 2024 - 11:16 PM |
