oooty21 |
Newbie ![]() Group: Members Posts: 7 Joined: 1-June 12 From: los angeles Member No.: 14,505 Region Association: None ![]() |
New to the 914 World, I will be posting a lot of questions. I just purchased my first 914, and it is going to need a lot of love. I am sure this has been posted in the past, but was unable to find it, so here it is: how do I adjust the front headlights, as one of them is trying to dig itself back under the hood. On my old Miata you could adjust the sinking headlight by gently pulling on the cover, but this one is at least an inch off, leaving a huge gap between the hood and the painted headlight cover. All help is greatly appreciated (IMG:style_emoticons/default/smile.gif)
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,545 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
1. Turn the headlights on, then turn them back off. That puts the headlight motor in the "down" position.
2. Remove the relay that you find under the black plastic cover in the front trunk. This will let you keep your fingers if you accidentally move the motor position. 3. Loosen the jamb nut on the headlight stop, located on the back wall of the headlight bucket next to the motor, and screw the slotted screw all the way in until it matches flush with the jamb nut. 4. Loosen the three screws on the inboard headlight pivot, located in the front trunk. 5. Loosen the 2 screws on the outboard headlight pivot, located under the fender. 6. Move the headlight assembly around until it fits the opening correctly. Hold it there and have a helper tighten all of the pivot bracket bolts. 7. Put the relay back in, and turn the lights on and off a couple of times. Verify that the headlight ends up adjusted correctly when closed. 8. Turn the headlights on. 9. Adjust the headlight stop until it makes contact with the bracket on the bottom of the headlight pivot arm. Make sure it is touching, but not pulling on the bracket. Then tighten the jamb nut. 10. Turn off headlights. Now go have a beer. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 18th June 2024 - 08:06 AM |
