> Front Coilovers for 914, no more torsion bars: Its off jackstands on on ground
bfrymire
post Jun 2 2012, 08:02 PM
Salsaholic
Just like the thread says:
I am putting this in:
(This has been posted in the Elephant racing poly bronze thread from the other day.)
Here's the driver side prepped and waiting to install.
Here's the passenger side installed.
GPR supplied the parts and did the setup for me. It has around 1 degree of negative camber as I am running Hoosier A6s. Bump steer kit also installed.
I also have their front sway bar, and will be installing that next.
Heh, I can sure tell I don't do this for a living. It took me a couple of hours to install and I still may take it apart again. (IMG:style_emoticons/default/smile.gif)
-- brett
lotus_65
post Jun 3 2012, 04:17 AM
looks spendy...
nice though!
bfrymire
post Jun 3 2012, 11:19 AM
Salsaholic
I am using 200lb springs for the initial setup, and am quite sure that will change. It's going to be interesting to see how the car handles afterward. This is a street/track car. It spends most of it's time autocrossing, but I do sometimes drive it around. And this leads into the 935 a-arms. I looked at those, and asked about them also. I was told that they would be too fragile in street use. Too bad.
The advantages are better variety of springs, larger range of height adjustment, and as someone said, slightly eaiser to change springs. I would be curious to hear from someone who has tracked this setup. (IMG:style_emoticons/default/smile.gif)
Costwise, I try not too look at the recipts too much. (IMG:style_emoticons/default/smile.gif) I had GPR do all the welding that needed to be done, and the installation of the ER Polybronze. I am a hobbiest-mechanic and didn't want to mess that part up. So:
This is $349
http://www.tarett.com/items/914-products/9...rcom-detail.htm
Add in bilstein shocks. (Don't remember the cost offhand. Can be found online.)
ER Polybronze set:
http://www.tarett.com/items/914-products/9...1x00-detail.htm
I then had to get a pair of 911 struts. Used around $600 or so.
I also added the bump-steer kit. About $289.
http://www.tarett.com/items/914-products/9...rbsk-detail.htm
I am sure i am forgetting something... (IMG:style_emoticons/default/smile.gif)
-- brett
bfrymire   Front Coilovers for 914   Jun 2 2012, 08:02 PM
okieflyr   I love the tuneability factor. Does the shock towe...   Jun 2 2012, 08:09 PM
bfrymire   I love the tuneability factor. Does the shock tow...   Jun 2 2012, 08:38 PM
effutuo101   Like!   Jun 3 2012, 12:03 AM
kg6dxn   Very cool. I think it may be a good idea to streng...   Jun 3 2012, 12:11 AM
RSrocket   Nice set up, me likes!   Jun 3 2012, 02:03 AM
carr914   Nice ! I will be doing the same thing to my 91...   Jun 3 2012, 03:52 AM
lotus_65   looks spendy... nice though!   Jun 3 2012, 04:17 AM
bfrymire   I am using 200lb springs for the initial setup, an...   Jun 3 2012, 11:19 AM
pjhaun   How much does that cost?!!!!!   Jun 3 2012, 08:30 AM
396   Me likes..what's the spring rate? ...enjoy in ...   Jun 3 2012, 09:02 AM
brant   I don't see people with coil overs really ever...   Jun 3 2012, 09:06 AM
McMark   :drooley: I was just reading about this setup. L...   Jun 3 2012, 09:08 AM
Andyrew   Whats the advantage here? All I see is less tir...   Jun 3 2012, 09:17 AM
brant   If you go to a full 935 adjustable a-arm you can d...   Jun 3 2012, 09:22 AM
stuttgart46   Is this for a track only car or will it still be s...   Jun 3 2012, 09:40 AM
jmill   You can buy the entire setup from Rebel Racing.   Jun 3 2012, 12:52 PM
SUNAB914   I know a guy locally that has those for sale on cr...   Jun 3 2012, 01:31 PM
stuttgart46   I know a guy locally that has those for sale on c...   Jun 4 2012, 09:11 AM
bfrymire   Update. All installed and drove it. Ran into to ...   Aug 12 2012, 06:14 PM
brant   most likely too low I played around with 4inches o...   Aug 13 2012, 09:05 AM
Madswede   I'll add that the funny rubbing noise is most ...   Aug 13 2012, 07:26 PM
bfrymire   Thanks guys. The funny noise was not the usual ti...   Aug 13 2012, 08:43 PM
bfrymire   Thanks guys. The funny noise was not the usual t...   Aug 20 2012, 12:50 PM
ArtechnikA   How much suspension travel do you have in bump? Be...   Aug 20 2012, 01:54 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:43 PM
