Fuchs 2.0L Alloys, lug bolts |
Java2570 |
Jun 4 2012, 06:17 AM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
I just purchased a set of Fuchs 2.0L alloys to put on my 74 2.0L 914. I currently have the "Dan Gurney"
copy wheels on the car. Upon investigating, the wheels are held on by nuts instead of the long lug bolts I've seen most cars use. Question: were the lug bolts stock with the 2.0L Fuchs alloys or did Porsche use lug nuts and studs on some of these cars? I'm just a bit confused of which is proper and if it matters. I haven't looked to see if I can possibly reuse the studs I have on the wheels now or not. I do know if I do that I'll need to get different lug nuts due to the ball end shape on the Fuchs. Thoughts?? |
billh1963 |
Jun 4 2012, 06:36 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
I just purchased a set of Fuchs 2.0L alloys to put on my 74 2.0L 914. I currently have the "Dan Gurney" copy wheels on the car. Upon investigating, the wheels are held on by nuts instead of the long lug bolts I've seen most cars use. Question: were the lug bolts stock with the 2.0L Fuchs alloys or did Porsche use lug nuts and studs on some of these cars? I'm just a bit confused of which is proper and if it matters. I haven't looked to see if I can possibly reuse the studs I have on the wheels now or not. I do know if I do that I'll need to get different lug nuts due to the ball end shape on the Fuchs. Thoughts?? Sounds like you have a modification. Every car I have seen uses bolts. I would pull the studs and use the bolts. |
Lo-Fi Version | Time is now: 8th June 2024 - 09:00 AM |
