Fuchs 2.0L Alloys, lug bolts |
Java2570 |
Jun 4 2012, 06:17 AM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
I just purchased a set of Fuchs 2.0L alloys to put on my 74 2.0L 914. I currently have the "Dan Gurney"
copy wheels on the car. Upon investigating, the wheels are held on by nuts instead of the long lug bolts I've seen most cars use. Question: were the lug bolts stock with the 2.0L Fuchs alloys or did Porsche use lug nuts and studs on some of these cars? I'm just a bit confused of which is proper and if it matters. I haven't looked to see if I can possibly reuse the studs I have on the wheels now or not. I do know if I do that I'll need to get different lug nuts due to the ball end shape on the Fuchs. Thoughts?? |
dangrouche |
Jun 4 2012, 08:17 AM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
I have Fuchs as well and my car was set up for autoX, this ia a great and costly modification (cuz the studs can cost $5 or $7 each); you now have studs like conventional cars; all you need now are regular steel lug nuts that are not closed on the end. if you don't want this set up, you could probably sell them to another member. just be careful and don't mess up the threads when you hammer the stud out. use a sacrificial lug nut and/or an impact hammer
Lo-Fi Version | Time is now: 8th June 2024 - 10:24 PM |
