tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
I have tried bleedling my brakes with three different types of bleeders and I have the same issue each time. I can get all the calipers to bleed properly except the passenger rear brake. Using the hand pump type of bleeder, I have pumped the right rear brake for a very long time and I still get bubbles. It never seems to change. I wasn't sure if I had speed bleeders or not so I removed the bleeder and found it was slightly bent (probably from over tightening). I put a new bleeder in and restarted the process- no change. Any ideas? I have not seen any fluid leaks. I have not tried to drive the car yet due to some engine issues. They were rebuilt fairly recently (by me)- is it possibel that I screwed something up? Seems to me that I would see a leak somewhere if I screwed up the rebuild.
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Gee, Steve. I could swear that I told you that would happen with the speed bleeders and that I had this same problem (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/poke.gif)
Lo-Fi Version | Time is now: 3rd September 2025 - 08:14 PM |
