markyb |
Member ![]() ![]() Group: Members Posts: 100 Joined: 27-November 11 From: Rochester, Michigan Member No.: 13,823 Region Association: None ![]() |
![]() I'm getting a bit of vibration and wiggle in the rear of the car at 60-65 MPH, irregardless of the RPM or gear that i'm in, and smoothes out over 65MPH. This would lead me to believe that it's something wrong from the trans shafts outward. Any suggestions on how to check play on the wheel bearings without a big teardown? Other ideas? Wheels and tires are in good shape and balanced... Thanks |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,350 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
What you describe is classic out of balance tires. How long ago were the wheels balanced? What kind of weights did they use? The clamp on weights won't stay on the Mahles. The glue on weights won't stay on a wheel with dirt, grease, brake dust, and grime on them. Balance jobs sometimes don't last very long. One panic stop and a small flat spot on a tire will throw the balance off.
Lo-Fi Version | Time is now: 23rd September 2025 - 12:55 AM |
