vapor lock, on a 95 degree day |
JimN73 |
Jun 16 2012, 07:55 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
This afternoon outside temp was at least 94. the car took a long time to start:crank, pump, wait, pump, crank, curse, crank.
Finally started, when I finished my errand it didn't want to start again. Vapor lock?? Is there a cure?? thanks, |
SirAndy |
Jun 17 2012, 12:06 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Also, make sure you're using the thick FI phenolic spacers between the heads and the intake runners. This helps insulating the intakes from the heat of the heads.
Without them, you can easily boil the fuel in the carb bowls after shutting off the engine when it's hot. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 09:55 PM |
