Removing stock fuel lines.., Whats the procedure for getting them out? |
speed metal army |
Jun 17 2012, 02:40 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Tank end first?And yank em through?
gothspeed |
Jun 18 2012, 11:17 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Done! It was actually easier to pull them back to the shifter access hole, then out of the same hole. When pulling from the firewall they wanted to hang up on something... Thanks for the tips ! I am getting ready to do this same task. So that is good info (IMG:style_emoticons/default/smile.gif)! What lines will you be putting in? Will you be installing the new lines through the firewall first? |
speed metal army |
Jun 18 2012, 07:31 PM
Done! It was actually easier to pull them back to the shifter access hole, then out of the same hole. When pulling from the firewall they wanted to hang up on something... Thanks for the tips ! I am getting ready to do this same task. So that is good info (IMG:style_emoticons/default/smile.gif)! What lines will you be putting in? Will you be installing the new lines through the firewall first? I will be installing 3/8" SS tube.Yep! Thru the firewall. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:16 PM |
