Ignore this post |
Ignore this post |
tornik550 |
Jun 18 2012, 07:56 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
My alternator hasn't been working for a long time. I have rebuilding my engine so I never needed one. I replaced it tonight with a new Bosch 55a (what a pain). I hooked everything up and now when I go to hook up the battery- the wire arcs across to the battery post when I try to hook it up- wtf!!! I am an electrical idiot (along with other things). Anything is possible. I have made no other changes other than the new alternator. Inside the alternator, I did have to hook up the harness wires. I hooked up three things on the inside of the alternator- the big red wire to the area pictured, the wire from the black box on the alternator to the area arrowed and the obvious three pronged plug. There was a rubber boot around the red plug that was brittle and I suppose may not be insulating the ring connector well however I dont see how that would be a big deal.
Attached image(s) |
Lennies914 |
Jun 18 2012, 08:04 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
How did you determine that your original alt. was bad? I would unplug the three prong harness and/or remove the voltage regulator off the relay board and see if it still arcs.
Lo-Fi Version | Time is now: 9th June 2024 - 11:43 PM |
