| jporsche914 |
May 30 2004, 06:19 PM
Member ![]() ![]() Group: Members Posts: 149 Joined: 9-March 04 From: colorado, springs Member No.: 1,769 |
I have been looking for new wheels for my 72 914 for a while now and came across these wheels on http://www.eaglewheels.com/. They are a reproduction Fuch wheels. Thay are seventeen pounds. Is 17 pounds light for a 914?? Thay are only 101 dollars which seens like a preaty good deal to me. What do you think. Do you guys know what size tire would fit on this rim.
Thanks Here are the demisions and stuff 15x5.5 Polished 4 on 130mm +35 mm 4.56 3029-06 1580 lbs. 17 lbs. $101 Attached image(s)
reverie I thought those wheels were discontinued. :huh:
... May 30 2004, 06:34 PM
Aaron Cox i think it has wrong offset ;) May 30 2004, 06:45 PM
ChrisReale i THINK THOSE ARE WEAKER THAN THE oem THAT THEY RE... May 30 2004, 06:48 PM
trekkor If they are the same off set as Riviera's or E... May 30 2004, 06:58 PM
jporsche914 I have stock steel rims on right now. What tire co... May 30 2004, 07:06 PM
trekkor I'm running 205/50/15 Falken Azenis. Very spec... May 30 2004, 07:11 PM
jporsche914 They are not the same offset. The empi wheels offs... May 30 2004, 07:16 PM
trekkor Measure the stock steel, if you would be so kind, ... May 30 2004, 07:20 PM
jporsche914 My 914 is in the shop so i cant measure the wheel.... May 31 2004, 06:18 PM
Brett W Why don't you just buy this set of Five Factor... May 31 2004, 11:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:36 PM |
