Hub swap, Swapping out original 4 lug for 5 |
ZacB20 |
Jun 19 2012, 07:55 PM
Newbie Group: Members Posts: 17 Joined: 6-June 12 From: Washington Member No.: 14,530 Region Association: None |
Need to swap out the original 4 lug for new 5 lug. Front and rear obviously. How much will it cost? What hubs should I use and who makes them? Thanks for the support guys!
brant |
Jun 19 2012, 08:44 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
the front "springs" are torsion bars
the 911 stock ones are bigger "stiffer" than stock 4 cylider ones... you can upgrade from there to a stiffer spring rate. you want to balance somewhat your rear spring rate to your front rates... |
ZacB20 |
Jun 19 2012, 08:50 PM
the front "springs" are torsion bars the 911 stock ones are bigger "stiffer" than stock 4 cylider ones... you can upgrade from there to a stiffer spring rate. you want to balance somewhat your rear spring rate to your front rates... I know there's a torsion bar stock. I've left it their but added coil springs also. It's actually not as ghetto as it sounds. It's been done on multiple different car builds including Porsches and VWs |
Lo-Fi Version | Time is now: 9th June 2024 - 11:40 PM |
