| Geezer914 |
Jun 28 2012, 08:46 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,300 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
I just finished installing Chris Foley's shift linkage kit. The car shifts smooth as silk like a normal car with a 5 speed. It's like night and day! There is no question what gear you are shifting into, the shifts are solid and tight. I first replaced all the bushings using the stock shifter. It was like "what gear am I going to find now?" It would grind going into 1st and my arm was hurting from pushing the shifter as hard as I could to the right to find 4th and 5th, and when shifting into 5th, finding 3rd instead! So I installed a Renn shifter, a little better, but not much. Was not happy. So I sprung for Chris's linkage kit and firewall bearing kit. The car is a pleasure to drive. Thanks Chris for a super engineering job and a high quality kit. If you are not happy with the way your car is shifting, I would highly recommend installing this kit. (IMG:style_emoticons/default/smilie_pokal.gif)
| moggy |
Jun 28 2012, 12:23 PM
Member ![]() ![]() Group: Members Posts: 192 Joined: 15-December 04 From: Wales Member No.: 3,285 |
I see no advantage over the Rennshift kit with that. Good to have an alternative I agree. But if your Rennshift like for like kit wasn't working, which looks exactly the same, then I would be asking myself whether it was installed and setup correctly in the first place.
| dadaDaveed |
Jun 28 2012, 01:03 PM
Member ![]() ![]() Group: Members Posts: 111 Joined: 19-February 09 From: San Antonio, TX Member No.: 10,071 Region Association: Southwest Region |
I see no advantage over the Rennshift kit with that. Good to have an alternative I agree. But if your Rennshift like for like kit wasn't working, which looks exactly the same, then I would be asking myself whether it was installed and setup correctly in the first place. I believe he was referring to just the Renn Shifter... not the linkage that James used to sell. |
| JRust |
Jun 28 2012, 01:57 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
I see no advantage over the Rennshift kit with that. Good to have an alternative I agree. But if your Rennshift like for like kit wasn't working, which looks exactly the same, then I would be asking myself whether it was installed and setup correctly in the first place. I believe he was referring to just the Renn Shifter... not the linkage that James used to sell. (IMG:style_emoticons/default/agree.gif) |
Geezer914 Chris Foley's Tangerine Racing shift linkage kit Jun 28 2012, 08:46 AM
76-914 :ttiwwp: Jun 28 2012, 09:01 AM
RobW
:ttiwwp:
:agree:
but I'm pretty sure its m... Jun 28 2012, 06:41 PM
Racer Chris
I'm pretty sure its mostly a long straigh... Jun 28 2012, 08:19 PM
JWest
FWIW my Rennshaft linkage popped off at the last ... Jun 28 2012, 10:02 PM
914340
I see no advantage over the Rennshift kit with th... Jun 28 2012, 12:54 PM
seanery The shifter and the linkage kit are apples and ora... Jun 28 2012, 06:01 PM
jim_hoyland
After 7 years, how's it working ? Any sugges... Jul 14 2019, 08:22 PM
mepstein Shifting in a 914 is a system, only as good as it... Jul 14 2019, 09:25 PM
Larmo63 Ask Keith, @914Toy
He has done both of thes... Jul 14 2019, 10:38 PM
914Toy
Ask Keith, [b]@[url=http://www.914world.com/bbs2... Jul 15 2019, 09:06 AM
VaccaRabite I have a Rennshift and one of Chris's kits in ... Jul 15 2019, 06:19 AM
jim_hoyland
I have a Rennshift and one of Chris's kits in... Jul 15 2019, 06:22 AM
Luke M
I have a Rennshift and one of Chris's kits in... Jul 16 2019, 06:32 AM
VaccaRabite
[quote name='VaccaRabite' post='2730109' date='Ju... Jul 16 2019, 08:16 AM
[quote name='VaccaRabite' post='2730109' date='J... Jul 16 2019, 08:18 AM
Luke M
[quote name='VaccaRabite' post='2730357' date='Ju... Jul 16 2019, 08:44 AM
Olympic 914
I've had that issue in my 71 which drove me... Jul 17 2019, 07:58 AM
VaccaRabite
When I adjusted the shifter, I needed to clearan... Jul 16 2019, 04:05 PM
Porschef
http://www.914world.com/bbs2/uploads_offsite/fbc... Jul 16 2019, 06:02 PM
gereed75 I have a Weltmiester short shift shifter. It simpl... Jul 15 2019, 06:25 AM
mepstein On my 3.2 conversion, I have a jwest shifter, full... Jul 15 2019, 06:32 AM
Cairo94507 Hi Mark- That is the exact set-up I have for my ca... Jul 15 2019, 06:38 AM
mepstein I almost forgot - Zach's handmade shift knob. ... Jul 15 2019, 06:51 AM
Eric_Shea Jim, We put them on everything. The spherical fir... Jul 16 2019, 02:50 PM
jim_hoyland Trigger pulled...: Just submitted an order along w... Jul 16 2019, 03:01 PM
StratPlayer You won't be sorry jim,, I've had one on m... Jul 16 2019, 03:22 PM
jim_hoyland
You won't be sorry jim,, I've had one on ... Jul 16 2019, 04:07 PM
maf914 Zach,
What did you use to cut off the console ear... Jul 17 2019, 07:33 AM
VaccaRabite
What did you use to cut off the console ear? A c... Jul 17 2019, 09:33 AM
frank_c
Also, do you use the rear console black plastic b... May 18 2026, 09:29 PM
brant shift console mods are great
they made another no... Jul 17 2019, 10:05 AM
brant the cup bushing extension is in the picture also Jul 17 2019, 10:05 AM
... Jul 17 2019, 10:30 AM
brant
the cup bushing extension is in the picture also... Jul 17 2019, 10:33 AM
ChrisFoley
at full extension a part of the plastic bushing ... Jul 17 2019, 10:38 AM
at full extension a part of the plastic bushing... Jul 17 2019, 11:25 AM
ChrisFoley Actually, Brant's picture is of a sideshift pi... Jul 17 2019, 11:42 AM
mepstein Sideshift or tail? Jul 17 2019, 12:08 PM
ChrisFoley Sideshift Jul 17 2019, 12:31 PM
Sideshift
Cool. Thanks! Jul 17 2019, 12:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th May 2026 - 12:56 AM |
