> twisted engine?, engine & transmission are rotated a bit to the driver's side
MarkS
post Jun 28 2012, 03:00 PM
Replacing my Monza muffler with something quieter and noticed one side of the exhaust was a good bit lower than the other. Once the exhaust was removed, it seems the whole engine + transmission is rotated a bit towards the driver's side.
Any clue as to why this would happen? Pics below. Thanks in advance.
MarkAttached Image Attached ImageAttached Image
jmill
post Jun 28 2012, 03:33 PM
Green Hornet
Looks like it's been fixed before. It's not as bad as you would think. Dr. Evil can hook you up with parts. I have two nose (or is it tail on a teener) cones hanging around my garage. I'm sure others closer to you have spares. I'd check the front engine mounts too. The rubber may be torn up.
MarkS
post Jun 28 2012, 03:40 PM
QUOTE(jmill @ Jun 28 2012, 05:33 PM) *
It does look like it may have been welded before.
What does the fix involve? Replacing the nose/tail?
Bartlett 914
post Jun 28 2012, 03:54 PM
QUOTE(MarkS @ Jun 28 2012, 04:40 PM) *
Looks like the transmission has been neglected. It can be changed in the car but I would suggest sending it out or do a swap. I am guessing you are way overdue for an oil change.
MarkS   twisted engine?   Jun 28 2012, 03:00 PM
TargaToy   Has your left transmission ear broken loose from t...   Jun 28 2012, 03:04 PM
SLITS   Either your mounts are bad / damaged / ?? or the b...   Jun 28 2012, 03:05 PM
rgalla9146   Either your mounts are bad / damaged / ?? or the ...   Jun 28 2012, 03:36 PM
jsayre914   take a picture of the rear of the tranny looking u...   Jun 28 2012, 03:14 PM
MarkS   ok, found it. see pics below. this does not look c...   Jun 28 2012, 03:22 PM
jmill   Looks like it's been fixed before. It's n...   Jun 28 2012, 03:33 PM
MarkS   Looks like it's been fixed before. It's ...   Jun 28 2012, 03:40 PM
Bartlett 914   Looks like it's been fixed before. It's...   Jun 28 2012, 03:54 PM
vsg914   Replace it. Has the car been in a wreck? That is u...   Jun 28 2012, 03:50 PM
jsayre914   Easy fix, you will have it up and running in a day...   Jun 28 2012, 03:53 PM
MarkS   Has not been in a wreck as far as I know. Ok, so ...   Jun 28 2012, 03:57 PM
jsayre914   Has not been in a wreck as far as I know. Ok, so...   Jun 28 2012, 04:04 PM
MarkS   ok, thank you.   Jun 28 2012, 04:09 PM
Valy   Since the ear broke twice in the same place there ...   Jun 28 2012, 04:37 PM
Dr Evil   Since the ear broke twice in the same place there...   Jun 29 2012, 12:58 PM
MarkS   Got it, thanks.   Jun 28 2012, 04:47 PM
jmill   Also, what else should I do while I'm back th...   Jun 28 2012, 07:35 PM
G e o r g e   Also, what else should I do while I'm back t...   Jun 28 2012, 07:49 PM
underthetire   Think you should change both the motor mounts and ...   Jun 28 2012, 09:19 PM
TargaToy   I'm amazed you were able to select all 5 gears...   Jun 28 2012, 09:25 PM
Dr Evil   Wow, let me know if I can help.   Jun 28 2012, 09:25 PM
MarkS   I was able to select all gears but did notice that...   Jun 29 2012, 04:56 AM
vsg914   There should be someone real close to you that has...   Jun 29 2012, 05:24 AM
MarkS   Was quoted $160 to fix it or $395 for a ...   Jun 29 2012, 10:21 AM
poorsche914   If you can find a tail shift cone (usually cheaper...   Jun 29 2012, 10:51 AM
Dr Evil   Don't be in a hurry. I will get back to u toni...   Jun 29 2012, 10:53 AM
MarkS   Great, thanks Dr Evil, (Mike?). I'm in no rush...   Jun 29 2012, 11:52 AM
monkeyboy   Whoa... It's 100+ in LA this week too... The ...   Jun 29 2012, 11:56 AM
- Lo-Fi Version Time is now: 1st August 2025 - 02:22 PM
