> twisted engine?, engine & transmission are rotated a bit to the driver's side
MarkS
post Jun 28 2012, 03:00 PM
Replacing my Monza muffler with something quieter and noticed one side of the exhaust was a good bit lower than the other. Once the exhaust was removed, it seems the whole engine + transmission is rotated a bit towards the driver's side.
Any clue as to why this would happen? Pics below. Thanks in advance.
MarkAttached Image Attached ImageAttached Image
jmill
post Jun 28 2012, 07:35 PM
Green Hornet
QUOTE(MarkS @ Jun 28 2012, 04:57 PM) *
Also, what else should I do while I'm back there? New rubber mounts? Anything else?
Check your front engine mounts. I think they're torn up putting extra stress on the left ear.
MarkS   twisted engine?   Jun 28 2012, 03:00 PM
TargaToy   Has your left transmission ear broken loose from t...   Jun 28 2012, 03:04 PM
SLITS   Either your mounts are bad / damaged / ?? or the b...   Jun 28 2012, 03:05 PM
rgalla9146   Either your mounts are bad / damaged / ?? or the ...   Jun 28 2012, 03:36 PM
jsayre914   take a picture of the rear of the tranny looking u...   Jun 28 2012, 03:14 PM
MarkS   ok, found it. see pics below. this does not look c...   Jun 28 2012, 03:22 PM
jmill   Looks like it's been fixed before. It's n...   Jun 28 2012, 03:33 PM
MarkS   Looks like it's been fixed before. It's ...   Jun 28 2012, 03:40 PM
Bartlett 914   Looks like it's been fixed before. It's...   Jun 28 2012, 03:54 PM
vsg914   Replace it. Has the car been in a wreck? That is u...   Jun 28 2012, 03:50 PM
jsayre914   Easy fix, you will have it up and running in a day...   Jun 28 2012, 03:53 PM
MarkS   Has not been in a wreck as far as I know. Ok, so ...   Jun 28 2012, 03:57 PM
jsayre914   Has not been in a wreck as far as I know. Ok, so...   Jun 28 2012, 04:04 PM
MarkS   ok, thank you.   Jun 28 2012, 04:09 PM
Valy   Since the ear broke twice in the same place there ...   Jun 28 2012, 04:37 PM
Dr Evil   Since the ear broke twice in the same place there...   Jun 29 2012, 12:58 PM
MarkS   Got it, thanks.   Jun 28 2012, 04:47 PM
jmill   Also, what else should I do while I'm back th...   Jun 28 2012, 07:35 PM
G e o r g e   Also, what else should I do while I'm back t...   Jun 28 2012, 07:49 PM
underthetire   Think you should change both the motor mounts and ...   Jun 28 2012, 09:19 PM
TargaToy   I'm amazed you were able to select all 5 gears...   Jun 28 2012, 09:25 PM
Dr Evil   Wow, let me know if I can help.   Jun 28 2012, 09:25 PM
MarkS   I was able to select all gears but did notice that...   Jun 29 2012, 04:56 AM
vsg914   There should be someone real close to you that has...   Jun 29 2012, 05:24 AM
MarkS   Was quoted $160 to fix it or $395 for a ...   Jun 29 2012, 10:21 AM
poorsche914   If you can find a tail shift cone (usually cheaper...   Jun 29 2012, 10:51 AM
Dr Evil   Don't be in a hurry. I will get back to u toni...   Jun 29 2012, 10:53 AM
MarkS   Great, thanks Dr Evil, (Mike?). I'm in no rush...   Jun 29 2012, 11:52 AM
monkeyboy   Whoa... It's 100+ in LA this week too... The ...   Jun 29 2012, 11:56 AM
- Lo-Fi Version Time is now: 1st August 2025 - 02:27 PM
