76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,757 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I mis-aligned my 12 pin connector on the relay board (less than a week after reading where Andy did this same thing) and burned up my Pertronix. (IMG:style_emoticons/default/sad.gif) This lead to re-installing points and condenser (IMG:style_emoticons/default/barf.gif) . For the life of me, I could not locate my timing mark when setting the timing. Verified TDC and repainted that mark thinking it might be more visible. Another 30-45 minutes of wasted time before I realized that I couldn't time off the #2 plug wire. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) Feeling remarkably confident, if not challenged, I moved on to adjusting my shifter. I noticed that 5th had become a challenge when in AZ (it had been on jack stands awaiting parts since) so I decided an adjustment was in order. I spent the next 1.5 hours "chasing" the correct shift pattern before I looked behind the rubber boot and found this. I was chasing my ass. Feeling stupid is easy. (IMG:style_emoticons/default/biggrin.gif)
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
Sorry to hear that Kent. Seems a rash of that happening.
Remember to always disconnect the battery when working with those connectors on the relay board. Mis-aligning the 14 pin can fry your harness if you don't have the red wires fused. That coupler bushing looks just like what mine did several years ago. Tom |
Lo-Fi Version | Time is now: 1st August 2025 - 12:48 PM |
