Washed my hands of Jake Raby |
stugray |
Jul 3 2012, 02:59 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Ok, so I have been building a race motor for over 2 years.
I have studied everything Jake Raby has to say, following his advice and buying his products almost exclusively (if engine related). (IMG:style_emoticons/default/pray.gif) Last week I bought (from the type IV store) a set of AA cylinders and KB hypereutectic pistons. the instructions in the box with the pistons said that I MUST increase the upper ring gap by 20-40% over the stock piston gaps. I measured the gaps on the hastings rings that I also purchased from Jake. They were both (upper & lower) exactly stock .015. I question Jake on his "Type IV store support" forum and he said that is how he uses them (stock). So I contacted the machinist that machined the pistons "United Engine and machine co, Carson city NV." they told me that I absolutely must increase the upper ring gap or it would break the ring and damage the piston and void the warranty. However they said that I should contact the manufacturer of the piston to get the exact number because it is specific to the particular application. I said I got them from Jake Raby, but the guy said that did not ring a bell. (IMG:style_emoticons/default/confused24.gif) I gave him the part number from the box and they said that customer was "European Motor Works in Hawthorne CA." So I call European Motor works, tell them the story and they tell me I must increase the upper ring gap on hypereutectic pistons or I will break the ring and void my warranty. The technician then tells me in excrutiating detail WHY that is so using hypereutectic pistons. So I post this information on a thread about this exact product on the Type IV support thread on Jake's site. Jake chewed me out for not blindly accepting his suggestion and made a comment something like "why do I even give advice?". I posted again something almost exactly the following (can't post it exactly as Jake has deleted the thread): (Jake you can post the exact text if you can recover it after deleting it) "Ok let me understand: 1 - I have read every technical thread and watched your assembly video numerous times and one thing I can tell about you is that you demand that everyone follows your instructions to the letter or void the warranty. 2 - You send me one of your products (P&Cs) which has instructions in the box which instruct me to increase the ring gap of the upper ring. I call the phone number on the instructions in the box, and the technical person on the other end tells me I need to increase the ring gap, but give me another number for the shop who designed this P&C combination. THEY tell me the same thing: increase upper ring gap by .010 or void the warranty. 3 - You then proceed to treat me like an A-hole trolling for information when in fact I am a customer that just purchased YOUR product." I then tell him he can keep his PAID FOR phone consultation because I dont need his kind of "Customer Service". I paid extra for a phone consultation when I purchased his cam package. So what does he do? He deletes the entire thread and does not even respond. (IMG:style_emoticons/default/sheeplove.gif) What kind of customer support is that after I have spent probably $3000 over the last two years from him. I know that it is not a $15k turn key engine, but why have a Type IV support forum, and treat CUSTOMER like dirt? Since I am positive that I have burned all bridges with Jake and will probably get flamed by him every time I post on the is forum from now on, I dont mind sharing the fact that: If you want to buy a P&C set, dont do it from Jake. Buy them from "European Motor Works" directly and save $115. http://www.europeanmotorworks.com/vw/type-...-cylinders.html Since apparently Jake just buys his from them, marks them up $115 and doesnt even open the box or he would have noticed the instructions in there and possibly replaced them with his own if he wanted you to do sometihng different. I have tried to put up with Jake's petty bitching about his customers because I might want some advice from him in the future. Now I just plain dont want it. I'd rather blow up one of his engines than deal with his self-righteous bull crap any longer. He complains that he does not have enough time to answer questions DIRECTLY from his customers because he is so busy. Then a GOOD business owner would either hire more help, or dont try to run an online store. So I am sure we will get one of Jakes diatribes about how he cant stand trying to support people who ask him questions..... even if they were paying customers who even paid extra for just his time alone. (IMG:style_emoticons/default/KMA.gif) Done with rant. Stu |
stugray |
Jul 3 2012, 05:00 PM
I have this to add from the KB website:
http://www.kb-silvolite.com/assets/kb_installation.pdf The very first thing on that page explains how you must open upper ring gap. http://www.kb-silvolite.com/article.php?ac...ead&A_id=32 "The Keith Black pistons unique thermal conductivity, ring location and varied end use requires special attention be paid to top ring end gap. KB pistons make more HP by reflecting heat energy back into the combustion process and, as a result, the top ring runs hotter and requires additional end clearance. Increasing ring end gap does not affect performance or oil control because normal end gaps are realized at operating temperatures. Failure to provide sufficient top ring end gap will cause a portion of the top ring land to break as the ring ends butt and lock tight in the cylinder. " So I guess Keith Black is Full Of crap too? And you notice what website you get when you try to find the KB website? The United Engine & machine CO. So those people that I contacted "United machine & engine co" and talked to their technical specialist knows nothing about their own pistons? And Jake, You keep wanting this thread to close... Why? Because you cant close it as you did on your own site? Why dont you just agree that I did nothing wrong by contacting Keith Black directly and asking questions that contradict your "technical expertise". |
Lo-Fi Version | Time is now: 10th June 2024 - 02:20 PM |
