tranny cooler questions -UPDATED, ...like...how, what, where??? |
naro914 |
Mar 28 2012, 06:02 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
Hey all,
so it's become obvious to me that I need a transmission cooler set up. With 330 hp and using a 901 box, it's going to start destroying gears (already did this past weekend at Road Atlanta). So, what is everyone using and how are they set up? What pump & cooler? are you using a resevior/tank? Where is the cooler mounted? and where are you getting the oil in and out of the trans? As you can see, I'm a complete newbie about this, need to educate and do as quickly as possible...I'm running out of transmissions! Pictures would be wonderful... thanks!! |
naro914 |
Jul 5 2012, 01:03 PM
any more pictures? Finally going to get around to doing this...
No, I'm not going to a 930, so lets stop that discussion. Looking at the pic from Patrick, I don't see a reseviour, and what is the red section right after where it attaches at the the drain plug? (I'm not in a place I can repost the picture) Also, can I assume you need some sort of temp switch to turn on the pump once it starts to get warm? (and not run it when the oil is cold) And....how do you fill it with oil? if you do it the 'normal' way, you lose oil that runs through the lines, pump and cooler, which will lower the oil level in the trans. |
Lo-Fi Version | Time is now: 6th June 2024 - 11:11 AM |
