> i've got 13", V8 air bleeding
smrz914
post Jun 1 2004, 10:30 PM
Soon to be brightening the life of the person behind you.
haha made you look. So was looking throught past posts to so exectly how to bleed the air out. I found that the front of the car should be 18" higher then the front. Is this true? This seems really high. I got it up 13" (no viagra), so i'm going to try and bleed it.
Also in the instructions it says to take it for a drive. do you lift the front up again when you get back home to bleed it? or leave it down.
neo914-6
post Jun 1 2004, 11:14 PM
neo life
I was just bleeding my system today. I'm basically running it until hot and opening the vent valves on the Renegade Rad. Found the leak at my Dedenbear tank sight tube. It got brittle and cracked. Good idea but probably should be glass. Also installed the Renegade elbow so no more kinks! Are you bringing the V8 to WCC, Paul?
Malmz,
Looks like the tank Renegade sells! Do they have the same supplier?
Felix
- Lo-Fi Version Time is now: 6th June 2025 - 03:55 AM
