> What type of puller to free rear brake disc, stuck again...... Got it thanks to Racer Chris..
wndsnd
post Jul 11 2012, 07:51 AM
You wanted a horse, but got a goat. Nobody wants a goat....
Got my rear calipers free finally by releasing the rear shock struck and dropping down the swing arm. This gave me more room and allowed me to get more leverage.
Solved that problem
Next the rear disc, got one screw out , the other I had to drill off the head, now I am looking for a puller. I can't seem to budge it with traditional methods.
(IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif)
ChrisFoley
post Jul 11 2012, 08:27 AM
I am Tangerine Racing
QUOTE(wndsnd @ Jul 11 2012, 08:51 AM) *
Solved that problem
The disc is a close fit onto the hub, and rust will make them stick together.
There should be two threaded holes in the disc which can be used for popping the disc off the hub using two 8mm bolts.
You can use a torch to heat the hat portion of the disc and expand it so it comes off the hub more easily.
wndsnd
post Jul 11 2012, 10:04 AM
QUOTE(Racer Chris @ Jul 11 2012, 10:27 AM) *
Solved that problem
Thanks Chris, but since I now only have one threaded hole, I am guessing it will bind. I will try again tonight.
ChrisFoley
post Jul 11 2012, 10:53 AM
QUOTE(wndsnd @ Jul 11 2012, 11:04 AM) *
I wasn't referring to the holes for the flathead screws.
There are two other holes in the rotor for jacking screws.
wndsnd
post Jul 11 2012, 11:11 AM
QUOTE(Racer Chris @ Jul 11 2012, 12:53 PM) *
That is great news..... I read the manual about using the 8m bolts and it didn't make sense to me.. I thought the threads were in the hub, not the disc.
- Lo-Fi Version Time is now: 13th July 2025 - 07:41 AM
