lonewolfe |
Senior Member ![]() ![]() ![]() Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California ![]() |
I've searched this topic and found a little information but was surprised there was not more. The search engine on this site leaves a lot to be desired. Anyhow, I'm relocating my fuel pump to the front of the car. I do not wish to put it in the front trunk so that leaves under the fuel tank or underneath the car close to the master cylinder underneath the stearing rack cover. Which location is best in your opinion? Any pro's or con's to either location?
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
one factor that never seems to be mentioned is how to correctly power the pump when relocating it and not having the pump run all the time with the key in the first position.
k |
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,454 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
one factor that never seems to be mentioned is how to correctly power the pump when relocating it and not having the pump run all the time with the key in the first position. k you're right mines that way and I'd sure like to find a link to a proper way to do it. what's the right way to do it with zero oil pressure shut off but allow the engine to start with no oil pressure? |
Lo-Fi Version | Time is now: 11th July 2025 - 03:42 AM |
